Full Version: OpenELEC Testbuilds for RaspberryPi (Kodi 16.0)
New OpenELEC Jarvis build #0828: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.6 #1 Fri Aug 28 21:03:55 BST 2015 armv6l GNU/Linux
# vcgencmd version
Aug 23 2015 19:27:51
Copyright (c) 2012 Broadcom
version 41b1f861989dc4d1bbe19a52361a248ae57ee82b (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150828210232-#0828-gc06668c [Build #0828]
# vcdbg log msg 2>&1 | grep DTOK
001574.643: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (c06668c5, changelog) and tip of XBMC master (4599e334, changelog) with the following modifications: Build Highlights:
  1. Kodi cosmetics
Build Details:
  1. XBMC:
    • FIX: AML zoom issues (PR:7907, 2 commits, 3 files changed)
    • [CONTAINERART] Fix Container.Art property for artist directories (PR:7877, 1 commit, 1 file changed)
    • Fix coverity #1312063 and #1312064 (PR:7802, 1 commit, 4 files changed)
  2. pvr.argustv:
    • [json] Fix download url (PR:28, 1 commit, 1 file changed)
  3. pvr.filmon:
    • [json] Fix missing depend and download url (PR:27, 1 commit, 2 files changed)
  4. pvr.pctv:
    • [json] Fix download url (PR:22, 1 commit, 1 file changed)
  5. pvr.stalker:
    • [json] Fix download url (PR:23, 1 commit, 1 file changed)
(2015-08-29, 00:10)popcornmix Wrote: [ -> ]
(2015-08-28, 23:26)polo_joe Wrote: [ -> ][quote='popcornmix' pid='2092266' dateline='1440781778']
I also get artifacts on 720p50 channels.
When setting Deinterlacing to auto, all is fine.
Are you overclocking? If so try disabling.
Otherwise a screenshot or photo of the artefacts would be useful.
Here's a short video of the artefacts.
https://www.dropbox.com/s/n454q8ykt1bpbv...9.mp4?dl=0
(2015-08-29, 08:10)polo_joe Wrote: [ -> ]Here's a short video of the artefacts.
I'd suggest you remove:
v3d_freq=400
sdram_freq=400
from config.txt
Looks better now, but artefacts are still there.
http://sprunge.us/ObaW
(2015-08-29, 12:16)polo_joe Wrote: [ -> ]Looks better now, but artefacts are still there.
I can also see this same issue. Not present with OMX acceleration Enabled
Only when using MMAL
Live TV, 1080 H264 stream
https://youtu.be/d33pn9GX6mw
Issue can be observed at;
4sec
16sec
42sec
44sec
51sec
[EDIT]
It is in fact also happening with OMX enabled, just not as often. I have only seen 3x glitches in 15 minutes with OMX whereas with mmal there was 5x in 1 minute
Can you add:
over_voltage=2
Is there anyway perhaps to make LiveTV (and playing back .ts recordings) use OMX and the analog output, whilst the rest defaults to MMAL and the DAC+?
That would at least enable my brother to use LiveTV with the lower quality analog output, until such time as MMAL can be made to work with LiveTV/.ts files and benefit from the higher quality audio from the DAC+ when watching movies/listening to music.
New OpenELEC Jarvis build #0829: RPi / RPi2
# uname -a
Linux rpi512 4.1.6 #1 Sat Aug 29 21:04:02 BST 2015 armv6l GNU/Linux
# vcgencmd version
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150829210313-#0829-gc06668c [Build #0829]
001561.476: Kernel trailer DTOK property says yes
Based on tip of OpenELEC master (c06668c5, changelog) and tip of XBMC master (ea582c6a, changelog) with the following modifications: Build Highlights:
  1. Kodi updates
Build Details:
  1. XBMC:
    • [video] fix title prompting in case the search returned no results (PR:7913, 1 commit, 1 file changed)
    • [xbmc][appmessenger] Fixed broken switch statement and moved it to it's own method to cut … (PR:7906, 1 commit, 2 files changed)
    • [ae] Fix copy-paste-error. (PR:7909, 1 commit, 1 file changed)
    • Revert "[osx/XBMCHelper] - compile XBMCHelper as 64bit" (PR:7775, 1 commit, 1 file changed)
(2015-08-29, 19:02)popcornmix Wrote: [ -> ]
Can you add:
over_voltage=2
It's the same with over_voltage=2
http://sprunge.us/TVUZ
(2015-08-30, 14:03)polo_joe Wrote: [ -> ]It's the same with over_voltage=2
Can try try over_voltage=4?
Or:
Can you try disable_auto_turbo=1?
(2015-08-24, 01:13)popcornmix Wrote: [ -> ]@illiac4 try the latest build with your misplaced subs file.
@doveman2 test if your seeking hang is fixed.
@popcornmix:
Is there a way to solve the misplaced subs for the RPi2 15.1 builds?
I've got a lot of them in PVR but can't update to the Kodi 16 builds on RPi2 of my children and wife.
Or is 16 stable enough for day to day usage?
(2015-08-30, 22:47)ricardosunnie Wrote: [ -> ]@popcornmix:
The subs fix has been backported to Isengard so will be in next OE stable build.
I use 16 for day to day usage and it's mostly stable, but there will be occasional breakages.
New OpenELEC Jarvis build #0830: RPi / RPi2
# uname -a
Linux rpi512 4.1.6 #1 Sun Aug 30 21:03:33 BST 2015 armv6l GNU/Linux
# vcgencmd version
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150830210226-#0830-g494f51d [Build #0830]
001579.059: Kernel trailer DTOK property says yes
Based on tip of OpenELEC master (494f51df, changelog) and tip of XBMC master (c336ec1a, changelog) with the following modifications: Build Highlights:
  1. OpenELEC and Kodi updates
Build Details:
  1. OpenELEC:
    • scripts/get: 900s is too much (PR:4292, 1 commit, 1 file changed)
    • pkg-config: allow pkg-config:host to be rebuilt (PR:4291, 1 commit, 1 file changed)
    • Update libbluray to 0.8.1 (PR:4290, 2 commits, 1 file changed)
  2. XBMC:
    • Updated addsong to check for iTrack aswell when checking for duplicates. (PR:7864, 1 commit, 1 file changed)
(2015-08-30, 16:37)popcornmix Wrote: [ -> ]
Or:
I tried both settings together and each alone.
No change.
mmal half works.
(2015-08-31, 17:44)polo_joe Wrote: [ -> ]I tried both settings together and each alone.
No change.
mmal half works.
Do you know anyone else with a pi2?
I would be interested if your sdcard, power supply, TV and peripherals doesn't have these artefacts with a different pi.
