Hi.
I've recently bought a RPi2 on the strength of the work that's been done to enable playing 3D MVC video, but I'm struggling to play any that doesn't result in a reboot.
Installed OE build is 22Sept #0922
I downloaded 3 samples from another OE thread, using shared links by popcornmix
Gravity
Thor
The Hobbit
I have them stored on my LAN and they play as 1080p in 2D, so as instructed, I renamed them to end the filename as <name>.3D.MVC.mkv
Now when I play them it just causes OE to crash and Pi needs to have pwr pulled.
I've tried them from both SMB share and also local SD card, same result.
If I just rename them to end <name>.3D.mkv they play in 2D still, adding the MVC causes this.
I've enabled in settings the play as Full HD 3D etc
Pi Audio is to 8 channel decode, its connected to an AV amp and PCM shows when playing in 2D.
Have I got the naming convention wrong or missing something else ?
kodi.log
http://pastebin.com/n4nfjU4a
(2015-09-23, 23:14)JustAnotherUser Wrote: [ -> ]I've recently bought a RPi2 on the strength of the work that's been done to enable playing 3D MVC video, but I'm struggling to play any that doesn't result in a reboot.
Can you give OE 5.95.5 a go? That should also support MVC mkv files (although not iso), and is pretty stable.
These builds are pretty experimental with a lot of changes each day (due to the switch to videoplayer).
will I have to do a clean install to go backwards or will dropping it into Update folder still work ?
I did an update, of 5.95.5 but it booted to a multi coloured screen, so I did a clean install, restoring various xml files (advancedsettings.xml etc) to set it up again ensuring the 3D options in settings were still set.
I put the samples files into the sd cards \Video folder and on playing the Thor clip with filename ending <name>.3D.mkv it played in 2D - there was no 3D option in the OSD
I renamed to end <name>.3D.MVC.mkv and whilst it didn't crash, it just played in 2D - again no 3D options in the OSD.
Can you advise further ?
This log includes it playing first as named .3D then as 3D.MVC
http://pastebin.com/xh6usep3
Another log but with full debug enabled
http://pastebin.com/U3xKsKYF
New OpenELEC Jarvis build #0923:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.8 #1 Wed Sep 23 21:05:21 BST 2015 armv6l GNU/Linux
# vcgencmd version
Sep 23 2015 12:21:14
Copyright (c) 2012 Broadcom
version c156d00b148c30a3ba28ec376c9c01e95a77d6d5 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150923210433-#0923-ga462c3c [Build #0923]
# vcdbg log msg 2>&1 | grep DTOK
001733.746: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (a462c3c9,
changelog) and tip of
XBMC master (fee4018a,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.1.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (2a9186e3, ahead +34)
- Includes latest kodi-platform master (15edaf78)
- Includes latest libcec master (e8506b3d, ahead +29)
- Includes latest libnfs master (e453431d, ahead +43)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (da6ee5dd), adsp.biquad.filters (d940a0d1, +1), adsp.freesurround (0bc31e26, +1), asplib (39fe0a71, +41), pvr.argustv (2bf67bb7), pvr.demo (659712a0), pvr.dvblink (4d718970), pvr.dvbviewer (0ca01b1a), pvr.filmon (f9fe3bd5), pvr.hts (7b8e2000, +1), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c), pvr.mythtv (702bda77, +2), pvr.nextpvr (40e7be2e), pvr.njoy (cc2c4a69), pvr.pctv (1494bfc1), pvr.stalker (837537de), pvr.vbox (bfbdec89), pvr.vdr.vnsi (8e0d73fb), pvr.vuplus (9ff818a4), pvr.wmc (3e396f5b)
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Exclude [env] rapidjson-01_native-what.patch: Use Kodi version for now
- Include [env] a42433e5: mesa: Bump to version 11.0.0
- Include [env] f407b769: Intel: Automatically switch to full range
- Include [env] 54fd6472: kodi: Remove 175 ms delay of advancedsettings (x86 only)
- Include [env] 147d730c: VAAPI: Enable EGL
- Include [env] compare: Kodi 16 updates
- Include [env] patch: Add kernel SDIO support
- Include [env] patch: Enable RapidJSON, drop YASL
- Include [env] patch: Enable pvr addons, disable PVR updates
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Enable RPi and some other touchscreens (similar to Raspbian)
- Include [env] patch: Add experimental splash video
- Include [pkg] patch: Fix for PR:113 (libcec)
- Include [pkg] patch: Fix xcode after videoplayer before PR8008
- Include [pkg] PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include [pkg] PR:8008: JSON: replace YAJL with RapidJSON
- Include [pkg] PR:8110: addon repositories: fix last checked time not updating if not previously added
- Revert [pkg] linux-999.20-mt7601u-support.patch: Reverted as patching order conflicts with rpi-4.1.y commits - continue using rpi-4.1.y equivalent (linux)
Build Highlights:
- New firmware
- New kernel 4.1.8
- Bump libusb, dbus
- Fix Python traceback generation and addon uninstalling
- VideoPlayer updates
Build Details:
- Firmware (Sep 23):
- video codec: Revert: Cleanup of fix for regression from refactor userdata release mechanics in categoriser commit See: link
- OpenELEC:
- libhdhomerun: update to libhdhomerun_20150826 (PR:4327, 1 commit, 1 file changed)
- linux: update to linux-4.1.8 (10c2a621)
- fuse-exfat: update to fuse-exfat-1.2.0, update links and license (9a466be3)
- remove package 'scons' (6912f505)
- dosfstools: update to dosfstools-3.0.28, update licence (adc71ae3)
- libusb: update to libusb-1.0.20, update license and link (d7006279)
- dbus: update to dbus-1.8.20 (935c3a82)
- libusb: fails to build if building parallel (d98f05a7)
- dvbhdhomerun: fix build with newer libhdhomerun (a462c3c9)
- XBMC:
- [fix][gui] Fix multi images in grouplists/layouts. (PR:8120, 1 commit, 1 file changed)
- Fix missing Python traceback caused by an invalid format string. (PR:8119, 1 commit, 1 file changed)
- [addons] fix uninstalling of non-repository addons (42227345)
- pvr.mythtv:
- 3.3.7 (PR:41, 2 commits, 2 files changed)
- newclock5:
- New commits in this build:
- [depends] fix target raspberry-pi (2bb5bcd4)
- [cmake] WIP: RPI (faf0139e)
- [cmake] build guilib with gif - TODO: add gif detection (8b23e9dc)
- [cmake] squash to resolution (1b6644b1)
- [depends] add kodi makefile for building with cmake - squash me (df77a098)
- sync cmake project (6f02de70)
- [EGL] don't always include amlogic (9008dc8d)
- VideoPlayer: clean audio interface (aab87640)
- disable passthrough when sync playback to display (44bb3e1b)
- fixes for audio sync (0405279b)
- Revert "disable passthrough when sync playback to display" (cf13b302)
- Revert "VideoPlayer: clean audio interface" (ae08cb3f)
- Updated commits in this build:
- Commits no longer in build:
- Updated: [env] compare: Kodi 16 updates
- Updated: [env] patch: Add kernel SDIO support
- Updated: [env] patch: Enable RPi and some other touchscreens (similar to Raspbian)
(2015-09-23, 01:40)parcel Wrote: [ -> ] (2015-09-22, 13:39)Milhouse Wrote: [ -> ]Debug-enabled #0921x builds uploaded: RPi / RPi2
Edit: @parcel/@Leopold: This bookmark crash definitely starts with #0919, ie. #0918 does not have this problem?
#0918 have problem.
Same bookmark didn't raise problem between different build, #0919 did but didn't in #0920.
http://xbmclogs.com/p8shges10
#if defined(TARGET_RASPBERRY_PI) || defined(HAS_IMXVPU)
// This code reduces rendering fps of the GUI layer when playing videos in fullscreen mode
// it makes only sense on architectures with multiple layers
if (g_graphicsContext.IsFullScreenVideo() && !m_pPlayer->IsPausedPlayback() && g_renderManager.IsVideoLayer())
fps = CSettings::GetInstance().GetInt(CSettings::SETTING_VIDEOPLAYER_LIMITGUIUPDATE);
#endif
unsigned int now = XbmcThreads::SystemClockMillis();
unsigned int frameTime = now - m_lastRenderTime;
if (fps > 0 && frameTime * fps < 1000)
m_skipGuiRender = true;
if (!m_bStop)
if (!m_skipGuiRender)
g_windowManager.Process(CTimeUtils::GetFrameTime());
g_windowManager.FrameMove();
There is may infinite recursive call on FrameMove it make stack overflow but I don't know what is
#0918 have problem.
If #0918 has this problem, does #0917? If #0917 has the problem, what about #0916? etc.
What is the *first build* with this problem? Maybe it's a build from a month or two ago. Can you identify which build is the first build with this problem?
(2015-09-24, 01:28)JustAnotherUser Wrote: [ -> ]I renamed to end <name>.3D.MVC.mkv and whilst it didn't crash, it just played in 2D - again no 3D options in the OSD.
The MVC tag has only been added in nightly builds. Use ".3D.SBS." as tag in Isengard builds.
(2015-09-24, 13:42)SpuDy Wrote: [ -> ] (2015-09-20, 05:58)SpuDy Wrote: [ -> ]Hello.
Since version 0916 when watching LiveTV after 2-3 seconds the picture is stuck audio is going on. (Pi2)
Build #0923 fixed it!
TY!
Yes I agree, with #0923 live tv seems to be working well again.
With latest build* the video-not-going-full-screen issue seems much better, but from time to time (1080p content) I still can hear audio starting while still in library view and then shortly after video goes full screen.
From time to time after seek I get no audio and it doesn't recover (pause/resume, seeking again have no effect) and need to stop and resume from there.
* I haven't watched HD content for a couple days (= couple builds).
Edit: nitpicking: although PLL adjust works fine ("err" in codec info reaches 0.0 ms) the "pll" value is not updating. With hdmi_clock_change_limit=40 it's always 0.9996 or 1.0004 even when err:0.0.
(2015-09-24, 15:42)menakite Wrote: [ -> ]Edit: nitpicking: although PLL adjust works fine ("err" in codec info reaches 0.0 ms) the "pll" value is not updating. With hdmi_clock_change_limit=40 it's always 0.9996 or 1.0004 even when err:0.0.
There was a bug there. It's meant to slow down as it approaches zero error. I've pushed a fix.
popcornmix
Sorry to continue to post about my issue where your samples arn't playing in 3D (do you wish me to star a new thread on it rather than here?)
"The MVC tag has only been added in nightly builds. Use ".3D.SBS." as tag in Isengard builds."
I renamed to <name>(year).3D.SBS.mkv and it goes to a blank screen, eventually coming back to the File List.
I'm stuck with this, does anybody have the 3 samples working (as Full HD 3D MVC playback) on OE 5.95.5 ?
http://pastebin.com/wQ6vWYbA
(2015-09-24, 21:02)JustAnotherUser Wrote: [ -> ]http://pastebin.com/wQ6vWYbA
There is a bugfix for 5.95.5 which will be in next version related to auto interlace. For now can you try a workaround.
Can you play a file that does work, and make sure deinterlace is set to auto or off, and deinterlace mode is set to Bob (anything other than auto should be okay).
Then select set as default for all videos. Then try the MVC file.
If not, then can you remove your advancedsettings.xml? This looks suspicious:
19:10:56 47.845375 T:1967988736 ERROR: GetResumeItemOffset - Cannot open VideoDatabase
Also can you try with omxplayer disabled which shouldn't have the auto deinterlace bug.
