Thanks @
menakite, I'd not spotted code was needed there.
FernetMenta We know when the Pi has finished it's part of the refresh rate change (it takes a few vsyncs and we do get a callback when that is done), but the TV may then take a number of seconds to stabilise, and there's nothing on the HDMI cable that shows when that is complete, so I don't think anything better can be done that using a GUI setting (or just living with losing the first few seconds).
(2015-10-03, 19:39)popcornmix Wrote: [ -> ](or just living with losing the first few seconds).
Don't sound like much, but losing the first few seconds is really annoying when watching short clips - having to skip back all the time
I've already asked about this on the
OS-independant forum, since I thought it was a general Jarvis issue
New OpenELEC Jarvis build #1003:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.10 #1 Sat Oct 3 21:56:59 BST 2015 armv6l GNU/Linux
# vcgencmd version
Oct 1 2015 21:08:23
Copyright (c) 2012 Broadcom
version 5fdecad11966c4bfe1848493f7f5ae15a60627a3 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151003214213-#1003-g6c9a6c5 [Build #1003]
# vcdbg log msg 2>&1 | grep DTOK
001717.882: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (6c9a6c55,
changelog) and tip of
XBMC master (3b6a503a,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.1.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (2a9186e3, ahead +34)
- Includes latest kodi-platform master (15edaf78)
- Includes latest libcec master (2c675dac, ahead +31)
- Includes latest libnfs master (82d2a228, ahead +19)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (0f624784, +2), adsp.biquad.filters (0c35df74, +7), adsp.freesurround (cf13262d, +2), asplib (39fe0a71, +41), pvr.argustv (2bf67bb7), pvr.demo (659712a0), pvr.dvblink (4d718970), pvr.dvbviewer (0ca01b1a), pvr.filmon (f9fe3bd5), pvr.hts (7b8e2000), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c), pvr.mythtv (702bda77), pvr.nextpvr (40e7be2e), pvr.njoy (cc2c4a69), pvr.pctv (1494bfc1), pvr.stalker (41fb7c42, +1), pvr.vbox (e92c1236), pvr.vdr.vnsi (8e0d73fb), pvr.vuplus (9ff818a4), pvr.wmc (3e396f5b)
- Exclude [env] kodi-100.99-keyboardlayouts-add-some-symbol-keys-to-english-qwer.patch: Revert - merged upstream
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Exclude [env] rapidjson-01_native-what.patch: Use Kodi version for now
- Include [env] 0b028b3e: Intel: Passthrough Mode - little workaround
- Include [env] c82208c2: Intel: Automatically switch to full range
- Include [env] 1efeabe1: VAAPI: Enable EGL
- Include [env] 09e988e6: mesa: Bump to version 11.0.0
- Include [env] 9af0f3c9: mesa: Bump to version 11.0.1
- Include [env] 92b2bf6d: Kodi: Use Limited Range by default
- Include [env] 374ec19e: Intel: Implement Passthrough-Range
- Include [env] compare: Kodi 16 updates
- Include [env] patch: Enable RapidJSON, drop YASL
- Include [env] patch: Enable pvr addons, disable PVR updates
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Add experimental splash video
- Include [env] patch: Disable Realtek WiFi Power Save (RTL8192CU/RTL8192DU/RTL8812AU)
- Include [env] PR:4358: [RBP] Add new kernel config options
- Revert [env] PR:4353: add mkpkg_binary-addons-Isengard and clean up mkpkg_kodi* (Revert until seo rebase)
- Revert [env] PR:4356: binary-addons: sync for isengard #4356 (Revert until seo rebase)
- Include [pkg] patch: Fix xcode after videoplayer before PR8008
- Include [pkg] PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include [pkg] PR:8008: JSON: replace YAJL with RapidJSON
- Include [pkg] PR:8133: [videodb] Fix TV shows cleaning after 5755573981ca706a82a7ecbbdf5de112a570377a.
- Include [pkg] PR:8147: Stereoscopic depth for Confluence
- Revert [pkg] linux-999.20-mt7601u-support.patch: Reverted as patching order conflicts with rpi-4.1.y commits - continue using rpi-4.1.y equivalent (linux)
Build Highlights:
- New kernel 4.1.10
- Bump glibc, libpng, libmicrohttpd
- Fix Video Settings dialog when using OMXPlayer
- Add support for the HiFiBerry DAC+ Pro
- @vdb86: This build disables power save in the RTL8192CU/RTL8192DU/RTL8812AU WiFi drivers - can you determine if this change has any effect on performance?
Build Details:
- OpenELEC:
- binary-addons: sync for isengard (PR:4356, 1 commit, 9 files changed)
- add mkpkg_binary-addons-Isengard and clean up mkpkg_kodi* (PR:4353, 3 commits, 3 files changed)
- Update Amlogic kernel and WeTek proprietary DVB module (PR:4348, 2 commits, 16 files changed)
- cpio: update to cpio-2.12 (f7a4e0a5)
- glibc: update to glibc-2.22 (5447e1f4)
- libpng: update to libpng-1.6.18 (cd56447d)
- mesa: update to mesa-10.6.9 (1d08244e)
- pciutils: update to pciutils-3.4.0 (88e7f0ed)
- libmicrohttpd: update to libmicrohttpd-0.9.44 (f21a27a9)
- linux: update to linux-4.1.10 (6c9a6c55)
- XBMC:
- Additional long-press modifications (PR:8093, 1 commit, 1 file changed)
- [coverity] Handle some coverity ids (PR:8113, 5 commits, 6 files changed)
- [guilib] add justify alignment for grouplist controls (PR:7809, 1 commit, 2 files changed)
- Minor cleanup for readability. (PR:8172, 1 commit, 1 file changed)
- Improve virtual keyboard layout for English (PR:8154, 1 commit, 1 file changed)
- [cleanup] silent reorder warning (PR:8173, 2 commits, 1 file changed)
- VideoPlayer: trust SAR of mkv container (PR:8168, 1 commit, 2 files changed)
- [input] fix onnext in dialog numeric after bab2486 (PR:8174, 1 commit, 1 file changed)
- Improve description of sets strings (PR:8106, 1 commit, 1 file changed)
- Update .gitignore for bootstrapped addons definition files (PR:8064, 1 commit, 1 file changed)
- LinuxInputDevice: add support for multi-touch devices (PR:8129, 1 commit, 6 files changed)
- Add Korean keyboard (PR:7952, 1 commit, 8 files changed)
- [cleanup] remove more xbox related things tidy up slightly (PR:7449, 4 commits, 4 files changed)
- [input] fix ios build after 7aeff92 (PR:8175, 1 commit, 1 file changed)
- correct offset by read ahead bytes when using SEEK_CUR/use ID3v2Tag instead of tag (PR:8107, 2 commits, 2 files changed)
- [input] add InputCodingTableKorean.cpp to Makefile (3af6f7d4)
- [input] xcode sync for InputCodingTableKorean (7aeff924)
- newclock5:
- New commits in this build:
- squash ae sync (262662a8)
- cmake: pi: add vcsm library (d54fadb7)
- [omxplayer] Ensure MMAL renderer is used in BYPASS mode (52bedf55)
- omxplayer: squash: Enable pause/resume again (e7af6ef0)
- Commits no longer in build:
- VideoPlayer: trust SAR of mkv container (a76c1015)
- LinuxInputDevice: add support for multi-touch devices (01034426)
- kernel 4.1.y_rebase:
- Add support for the HiFiBerry DAC+ Pro. (c6e87f4d)
I'm still having issues with my USB tuner randomly disappearing, even plugged directly into the RPi.
However, the issue I want to report particularly is that I can't get the EPG to display properly. It shows the channels and programmes for Radio but for TV it shows neither, even though TV - Channels lists both the TV and Radio channels. I tried clear data under Guide but that hasn't helped.
http://pastebin.com/BRe6fKkR
(2015-10-03, 19:39)popcornmix Wrote: [ -> ]Thanks @menakite, I'd not spotted code was needed there.
@FernetMenta We know when the Pi has finished it's part of the refresh rate change (it takes a few vsyncs and we do get a callback when that is done), but the TV may then take a number of seconds to stabilise, and there's nothing on the HDMI cable that shows when that is complete, so I don't think anything better can be done that using a GUI setting (or just living with losing the first few seconds).
popcornmix I f you have an idea how to promote this into general code, let me know. Pausing or some other appropriate action after changing refresh rate is not VideoPlayer specific. paplayer or picture view need this too. That was the reason I removed the gui setting from the video section and moved it to system - video.
I got stop playing after buffering in online streaming news addons(RT and CBSN).
Is it problem with power saving disabled in Realtek chipset wifi?
(2015-10-04, 15:36)parcel Wrote: [ -> ]I got stop playing after buffering in online streaming news addons(RT and CBSN).
Presumably you are using a Realtek WiFi chipset... would be a little surprising though as logically enabling power save is more likely to cause flaky WiFi... anything in kodi.log and dmesg/journalctl?
I dont know what happend but after updating to new build #1003 i can use web interface without problem
(2015-09-15, 11:32)grayback Wrote: [ -> ]Hello,
I tested it with nightly build on windows and the subtitle is working good. I just have the video half cut because kodi on windows can't handle 3D MVC MKV.
I made some other tests on my raspberry and the subtitle is ok when I deactivate "stereoscopic mode", kodi is just playing the file like a classic 2D file (ignoring the MVC stream). So I have the problem only in 3D stereoscopic and 2D monoscopic mode.
I tested older builds and last openelec beta and I have the same problem.
Hello,
I made a mkv sample with the subtitle problem :
https://drive.google.com/file/d/0B1UIMsl...sp=sharing
@ popcornmix : could you have a look?
Don't think so, for me player stops playing mkv's from NFS share on LAN, after couple of seconds from start, with the 100% buffering message.
It happens only when "Sync playback to display" option is enabled, does not matter what a/v sync method is used.
New OpenELEC Jarvis build #1004:
RPi /
RPi2
# uname -a
Linux rpi512 4.1.10 #1 Sun Oct 4 22:09:44 BST 2015 armv6l GNU/Linux
# vcgencmd version
Oct 4 2015 17:47:18
version e7d3d0fe7ae383863dbf177ba62c0807b12df0d5 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151004220853-#1004-g5a03629 [Build #1004]
001736.366: Kernel trailer DTOK property says yes
Based on tip of
OpenELEC master (5a036290,
XBMC master (d47ae09a,
- Includes latest addons: adsp.basic (0f624784), adsp.biquad.filters (0c35df74), adsp.freesurround (cf13262d), asplib (39fe0a71), pvr.argustv (2bf67bb7, +29), pvr.demo (659712a0), pvr.dvblink (4d718970, +19), pvr.dvbviewer (0ca01b1a, +17), pvr.filmon (f9fe3bd5, +18), pvr.hts (7b8e2000), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c, +30), pvr.mythtv (702bda77), pvr.nextpvr (40e7be2e, +19), pvr.njoy (cc2c4a69, +16), pvr.pctv (1494bfc1, +18), pvr.stalker (41fb7c42), pvr.vbox (e92c1236, +32), pvr.vdr.vnsi (8e0d73fb), pvr.vuplus (9ff818a4), pvr.wmc (3e396f5b, +22)
- Include [env] 0af7c611: Linux: Move Color range to 4.1.10
- Include [env] 173291da: mesa: Bump to version 11.0.2
Build Highlights:
- New firmware
- Revert memcpy optimisation in newclock5 - possible fix for Bluray ISO crashes (@cobric, @scotty144, @Azimono - please confirm)
- Possible fix for when "Dim" screensaver remains permanently enabled under certain circumstances
- Updated PR8147 fixing tag in profile login screen reported by @fab67
Build Details:
- Firmware (Oct 4):
- firmware: arm_loader: Add clear of polled register so linux doesn't report a timeout in bcm2709_boot_secondary. See: link
- firmware: arm_loader: Fix HAT probing to always restore the original state. See: link
- OpenELEC:
- [RBP] Add new kernel config options (PR:4358, 2 commits, 2 files changed)
- imx-vpu: update to imx-vpu-5.4.31 (4bfb7217)
- libXi: update to libXi-1.7.5 (9f3409e4)
- pixman: update to pixman-0.32.8 (dbf14ed5)
- pvr.mythtv: update to pvr.mythtv-8cb158c (94fc979e)
- XBMC:
- [videothumbloader] skip thumb extraction for bluray items (PR:8156, 1 commit, 1 file changed)
- [addons] move rollback feature to the update dialog (PR:8167, 3 commits, 5 files changed)
- CMusicInfoTag: Add missing MBID values when set from artist, album and song.… (PR:8079, 1 commit, 5 files changed)
- newclock5:
- [screensaver] Avoid getting stuck in dim state when skin is reloaded (cf77f5d0)
- Revert "[demuxer] Avoid memcpy on every demuxer packet" (d9bd2e7c)
- Updated: [env] compare: Kodi 16 updates
- Added: [env] 0af7c611: Linux: Move Color range to 4.1.10
- Added: [env] 173291da: mesa: Bump to version 11.0.2
(2015-10-04, 15:39)Milhouse Wrote: [ -> ] (2015-10-04, 15:36)parcel Wrote: [ -> ]I got stop playing after buffering in online streaming news addons(RT and CBSN).
It works after "Sync playback to display" option to disabled.
(2015-10-04, 20:30)Torentux Wrote: [ -> ] (2015-10-04, 15:36)parcel Wrote: [ -> ]I got stop playing after buffering in online streaming news addons(RT and CBSN).
Thank you it works.
(edit) Additionally in my case, 'Adjust display refresh rate to match video' option works better.
CBSN addon still stop after buffering with 'Sync playback to display' disabled. It's not error, just stop.
(edit) 'Adjust display refresh rate to match video' also not work on CBSN addon.
(edit) It also happens on RPi2's builtin LAN port. It is not a WLAN problem.
http://xbmclogs.com/piid3buwv#
