2015-07-05, 11:59
I have a Windows Server 2012 NUC with mySQL and Network shares. When i copy my advancedsettings to any other windows device it just work like a charm. I open kodi, i have my videosources and my musicsources, when i go to add videos there is my saved smb://192... entry from mediasources.xml loaded over the network! When i upload the advancedsettings to any android device it shows me the videos and the music what means that the part of mySQL is working, but when i try to play it says that the source for this file is missing. When i go to videos -> files, my sources from smb://192.168.37.4/kodi/userdata/sources.xml are missing / not loaded and i dont see my saved SMB entries when i will add new sources, but this should be loaded over smb://192.168.37.4/kodi/userdata/mediasources.xml . I wasted much hours now and i stuck on that point. Can someone help me please? I don't see or find any error in the kodi.log, i also activated debugging mode, there is NOTHING!
advancedsettings.xml
sources.xml:
mediasources:
kodi.log:
<advancedsettings>
<pathsubstitution>
<substitute>
<from>special://profile/sources.xml</from>
<to>smb://192.168.37.4/kodi/userdata/sources.xml</to>
</substitute>
<substitute>
<from>special://profile/mediasources.xml</from>
<to>smb://192.168.37.4/kodi/userdata/mediasources.xml</to>
</substitute>
</pathsubstitution>
<network>
<buffermode>0</buffermode>
<cachemembuffersize>20971520</cachemembuffersize>
<readbufferfactor>1</readbufferfactor>
</network>
<videodatabase>
<type>mysql</type>
<host>192.168.37.4</host>
<port>3306</port>
<user>username!</user>
<pass>password!</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<dateadded>0</dateadded>
</videolibrary>
</advancedsettings>
sources.xml:
<sources>
<programs>
<default pathversion="1"></default>
</programs>
<video>
<source>
<name>filme</name>
<path pathversion="1">smb://192.168.37.4/videos/filme/</path>
<allowsharing>true</allowsharing>
</source>
<source>
<name>serien</name>
<path pathversion="1">smb://192.168.37.4/videos/serien/</path>
</source>
<source>
<name>superneu</name>
<path pathversion="1">smb://192.168.37.4/videos/superneu/</path>
</source>
</video>
<music>
<source>
<name>musik</name>
<path pathversion="1">smb://192.168.37.4/musik/</path>
</source>
</music>
<pictures>
</pictures>
<files>
</files>
</sources>
mediasources:
<mediasources>
<network>
<location id="0">smb://username:[email protected]/videos</location>
<location id="1">smb://username:[email protected]/musik</location>
</network>
</mediasources>
kodi.log:
11:34:58 T:1519214104 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:34:58 T:1519214104 NOTICE: -----------------------------------------------------------------------
11:34:58 T:1519214104 NOTICE: Starting Kodi (14.2 Git:2015-03-26-7cc53a9-dirty). Platform: Android ARM 32-bit
11:34:58 T:1519214104 NOTICE: Using Release Kodi x32 build
11:34:58 T:1519214104 NOTICE: Kodi compiled Mar 26 2015 by GCC 4.8.0 for Android ARM 32-bit API level 14 (API level 14)
11:34:58 T:1519214104 NOTICE: Running on Amazon AFTM with Android 4.2.2 API level 17, kernel: Linux ARM 32-bit version 3.0.31+
11:34:58 T:1519214104 NOTICE: FFmpeg version: 14.2rc1-Helix-5-g7cc53a9-xbmc-2.4.6-Helix
11:34:58 T:1519214104 NOTICE: Host CPU: ARMv7 Processor rev 0 (v7l), 2 cores available
11:34:58 T:1519214104 NOTICE: Product: montoya, Device: montoya, Board: capri - Manufacturer: Amazon, Brand: BRCM, Model: AFTM, Hardware: montoya
11:34:58 T:1519214104 NOTICE: ARM Features: Neon enabled
11:34:58 T:1519214104 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
11:34:58 T:1519214104 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
11:34:58 T:1519214104 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
11:34:58 T:1519214104 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
11:34:58 T:1519214104 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
11:34:58 T:1519214104 NOTICE: The executable running is:
11:34:58 T:1519214104 NOTICE: Local hostname: localhost
11:34:58 T:1519214104 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
11:34:58 T:1519214104 NOTICE: load settings...
11:34:58 T:1519214104 DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 17
11:34:58 T:1519214104 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
11:34:58 T:1519214104 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
11:34:58 T:1519214104 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
11:34:58 T:1519214104 NOTICE: Found 1 Lists of Devices
11:34:58 T:1519214104 NOTICE: Enumerated AUDIOTRACK devices:
11:34:58 T:1519214104 NOTICE: Device 1
11:34:58 T:1519214104 NOTICE: m_deviceName : AudioTrack
11:34:58 T:1519214104 NOTICE: m_displayName : android
11:34:58 T:1519214104 NOTICE: m_displayNameExtra: audiotrack
11:34:58 T:1519214104 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:34:58 T:1519214104 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
11:34:58 T:1519214104 NOTICE: m_sampleRates : 48000
11:34:58 T:1519214104 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
11:34:58 T:1519214104 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:34:58 T:1519214104 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
11:34:58 T:1519214104 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<pathsubstitution>
<substitute>
</substitute>
<substitute>
</substitute>
</pathsubstitution>
<network>
</network>
<videodatabase>
<type>mysql</type>
<port>3306</port>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
</musicdatabase>
<videolibrary>
</videolibrary>
</advancedsettings>
11:34:58 T:1519214104 DEBUG: Configuring path substitutions
11:34:58 T:1519214104 DEBUG: Registering substition pair:
11:34:58 T:1519214104 DEBUG: From: [/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata/sources.xml]
11:34:58 T:1519214104 DEBUG: To: [smb://192.168.37.4/kodi/userdata/sources.xml]
11:34:58 T:1519214104 DEBUG: From: [/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata/mediasources.xml]
11:34:58 T:1519214104 DEBUG: To: [smb://192.168.37.4/kodi/userdata/mediasources.xml]
11:34:58 T:1519214104 WARNING: VIDEO database configuration is experimental.
11:34:58 T:1519214104 NOTICE: Default DVD Player: dvdplayer
11:34:58 T:1519214104 NOTICE: Default Video Player: dvdplayer
11:34:58 T:1519214104 NOTICE: Default Audio Player: paplayer
11:34:58 T:1519214104 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:34:58 T:1519214104 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
11:34:59 T:1519214104 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:34:59 T:1519214104 NOTICE: Loaded playercorefactory configuration
11:34:59 T:1519214104 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:34:59 T:1519214104 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:34:59 T:1516443744 NOTICE: Thread ActiveAE start, auto delete: false
11:34:59 T:1516446096 NOTICE: Thread AESink start, auto delete: false
11:34:59 T:1519214104 NOTICE: Running database version Addons16
11:34:59 T:1519214104 NOTICE: ADDONS: Using repository repository.xbmc.org
11:34:59 T:1519214104 WARNING: Unable to resolve: /libcec.so CECInitialise, reason: Symbol not found:
11:34:59 T:1519214104 ERROR: Unable to resolve exports from dll libcec.so
11:34:59 T:1519214104 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
11:34:59 T:1518700696 NOTICE: Thread PeripBusUSB start, auto delete: false
11:34:59 T:1519214104 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
11:34:59 T:1519214104 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
11:34:59 T:1519214104 NOTICE: Previous line repeats 1 times.
11:34:59 T:1519214104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
11:34:59 T:1519214104 NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
11:34:59 T:1519214104 NOTICE: Checking resolution 16
11:34:59 T:1519214104 NOTICE: GL_VENDOR = Broadcom
11:34:59 T:1519214104 NOTICE: GL_RENDERER = VideoCore IV HW
11:34:59 T:1519214104 NOTICE: GL_VERSION = OpenGL ES 2.0
11:34:59 T:1519214104 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
11:34:59 T:1519214104 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_EXT_debug_marker
11:34:59 T:1519214104 NOTICE: No Joystick name specified, loading default map
11:34:59 T:1519214104 NOTICE: Previous line repeats 36 times.
11:34:59 T:1519214104 NOTICE: Running database version ViewModes6
11:34:59 T:1519214104 NOTICE: Running database version Textures13
11:34:59 T:1519214104 NOTICE: Running database version MyMusic48
11:34:59 T:1519214104 NOTICE: Running database version MyVideos90
11:34:59 T:1519214104 NOTICE: Running database version TV26
11:34:59 T:1519214104 NOTICE: Running database version Epg8
11:35:00 T:1519214104 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
11:35:00 T:1519214104 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
11:35:00 T:1519214104 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
11:35:00 T:1519214104 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:35:00 T:1541301008 NOTICE: Thread LanguageInvoker start, auto delete: false
11:35:00 T:1519214104 NOTICE: initialize done
11:35:00 T:1519214104 NOTICE: Running the application...
11:35:00 T:1541301008 NOTICE: -->Python Interpreter Initialized<--
11:35:01 T:1636953488 NOTICE: Thread JobWorker start, auto delete: true
11:35:02 T:1519214104 NOTICE: starting zeroconf publishing
11:35:02 T:1636560912 NOTICE: Thread ZerocconfEmbedded start, auto delete: false
11:35:02 T:1519214104 NOTICE: ES: Starting event server
11:35:02 T:1637560472 NOTICE: Thread EventServer start, auto delete: false
11:35:02 T:1637560472 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:35:02 T:1637560472 NOTICE: UDP: Listening on port 9777
11:35:02 T:1636696024 NOTICE: Thread TCPServer start, auto delete: false
11:35:02 T:1519214104 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
11:35:02 T:1637546544 NOTICE: Thread JobWorker start, auto delete: true
11:35:02 T:1519214104 NOTICE: GL_VENDOR = Broadcom
11:35:02 T:1519214104 NOTICE: GL_RENDERER = VideoCore IV HW
11:35:02 T:1519214104 NOTICE: GL_VERSION = OpenGL ES 2.0
11:35:02 T:1519214104 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
11:35:02 T:1519214104 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_EXT_debug_marker
11:35:02 T:1637257280 NOTICE: Thread RSSReader start, auto delete: false
11:35:06 T:1636704648 NOTICE: Thread JobWorker start, auto delete: true
11:35:10 T:1528346112 NOTICE: Thread BackgroundLoader start, auto delete: false
