2015-07-05, 16:50
Issue with 1080 playback on Kodi Isengard15.0 RC1
It appears that Kodi 15.0 RC1 either has changed the names of codecs or is no longer processing some video settings in advancedsettings.xml
On an Amazon Fire Stick it is necessary to turn off stagefright to play SD videos, and turn it on to play HD without stuttering. To do that I have the following in my advancedsettings.xml:
The above works fine in 14.2, 15.0 BETA1 and 15.0 BETA2. It does not work in Kodi 15.0 RC1. Have the codec names changed or is something not functioning correctly?
The result is that HD videos stutter and the audio is out of sync by 4-5 seconds, making them unwatchable. You can see this by loading the Syfy addon from the Kodi.org repo and try playing any episode of Killjoys. Works fine using the above advancedsettings on earlier versions (and Windows 8.1 even using RC1), just doesn't work on Android on the Fire Stick.
If I remove the stagefright settings, the SD videos stutter.
I can load logs if needed, but I can't see anything different in them.
<video>
<stagefright>
<!-- -1 is default, 0 is never used this codec, 1 is always use this codec, bypassing blacklist -->
<useavccodec>hd</useavccodec>
<usevc1codec>hd</usevc1codec>
<usevpxcodec>hd</usevpxcodec>
<usemp4codec>hd</usemp4codec>
<usempeg2codec>hd</usempeg2codec>
<useswrenderer>false</useswrenderer>
</stagefright>
</video>
