It takes so much time looking for the show I want from the huge list, I couldnt find any place to search by name in Kodi, isnt there something like it in there?
It is on the pop up window that slides in from the left.
when you're in your movie library and you use a keyboard you can use shift+first letter of the movie you're searching for.
with a remote you can use the number keyboard like you would use SMS for the first letter.
also you can try to use the following add-on
Add-on:Global_Search (wiki)
