2015-07-08, 10:20
Hi Community,
I have the following situation, and I´m very sure it can be solved with the existing features of KODI.
For movies with HD-Audio (DTS MASTER HD, etc.), I need to set an audio-delay of 0,125 s, to keep audio and video in sync.
As most of my movies have HD-Audio, I´ve set this as my "default-value" for all movies, so that´s fine
But of course, there are some movies without HD-Audio (only DTS, Dolby-Digital), and for these I don´t need an according delay.
I can adjust the delay, by pressing the key "a" on my keyboard, and adjust the marker to the corresponding position: need to press the "->" key 5 times, to set audio-delay from 0,125 to 0,000.
So I was thinking of a "macro", the would do this for me. So pressing a specified key, will run a "macro" that does the according procedure (pressing "a", followed by pressing "->" 5 times).
Is it possible to do this with the "keymap.xml" or something like that?
Of course, the best way to solve it, would be to set different "defaults", depending on the Audi-Track, but that´s probably not possible...
I like to make the software more usable for my kids
Thank you for your input/thoughts.
Regards,
Chris
Regards,
Chris
