Full Version: Kodi not working....
I had kodi working yesterday then this morning after an update I believe it wont respond. Ive tried uninstalling and reinstalling but it still dont respond and open. Do anyone have any clue of what it could be? any help is greatly appreciated.
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Thu Jul 9 15:41:50 PDT 2015
Kodi Options:
Arch: x86_64
Kernel: Linux 3.13.0-57-generic #95-Ubuntu SMP Fri Jun 19 09:28:15 UTC 2015
Release: Ubuntu 14.04.2 LTS, Trusty Tahr
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/blacktarzan/core (2015-07-09 15:41:50.011603984 -0700)
[New LWP 2492]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGABRT, Aborted.
#0 0x00007fdba310ecc9 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
Thread 1 (Thread 0x7fdbaac767c0 (LWP 2492)):
#1 0x00007fdba31120d8 in __GI_abort () at abort.c:89
#2 0x00007fdba314b394 in __libc_message (do_abort=do_abort@entry=1, fmt=fmt@entry=0x7fdba3259b28 "*** Error in `%s': %s: 0x%s ***\n") at ../sysdeps/posix/libc_fatal.c:175
#3 0x00007fdba315766e in malloc_printerr (ptr=<optimized out>, str=0x7fdba3255c19 "free(): invalid pointer", action=1) at malloc.c:4996
#4 _int_free (av=<optimized out>, p=<optimized out>, have_lock=0) at malloc.c:3840
#5 0x0000000000faa4c2 in CVariant::cleanup() ()
#6 0x0000000000840334 in std::_Rb_tree<std:Confusedtring, std::pair<std:Confusedtring const, CVariant>, std::_Select1st<std::pair<std:Confusedtring const, CVariant> >, std::less<std:Confusedtring>, std::allocator<std::pair<std:Confusedtring const, CVariant> > >::_M_erase(std::_Rb_tree_node<std::pair<std:Confusedtring const, CVariant> >*) ()
#7 0x0000000000840327 in std::_Rb_tree<std:Confusedtring, std::pair<std:Confusedtring const, CVariant>, std::_Select1st<std::pair<std:Confusedtring const, CVariant> >, std::less<std:Confusedtring>, std::allocator<std::pair<std:Confusedtring const, CVariant> > >::_M_erase(std::_Rb_tree_node<std::pair<std:Confusedtring const, CVariant> >*) ()
#8 0x0000000000840327 in std::_Rb_tree<std:Confusedtring, std::pair<std:Confusedtring const, CVariant>, std::_Select1st<std::pair<std:Confusedtring const, CVariant> >, std::less<std:Confusedtring>, std::allocator<std::pair<std:Confusedtring const, CVariant> > >::_M_erase(std::_Rb_tree_node<std::pair<std:Confusedtring const, CVariant> >*) ()
#9 0x0000000000840327 in std::_Rb_tree<std:Confusedtring, std::pair<std:Confusedtring const, CVariant>, std::_Select1st<std::pair<std:Confusedtring const, CVariant> >, std::less<std:Confusedtring>, std::allocator<std::pair<std:Confusedtring const, CVariant> > >::_M_erase(std::_Rb_tree_node<std::pair<std:Confusedtring const, CVariant> >*) ()
#10 0x0000000000840327 in std::_Rb_tree<std:Confusedtring, std::pair<std:Confusedtring const, CVariant>, std::_Select1st<std::pair<std:Confusedtring const, CVariant> >, std::less<std:Confusedtring>, std::allocator<std::pair<std:Confusedtring const, CVariant> > >::_M_erase(std::_Rb_tree_node<std::pair<std:Confusedtring const, CVariant> >*) ()
#11 0x0000000000faa491 in CVariant::cleanup() ()
#12 0x0000000000ea74a8 in CUPowerSource::Update() ()
#13 0x0000000000ea75b7 in CUPowerSource::CUPowerSource(char const*) ()
#14 0x0000000000ea77e1 in CUPowerSyscall::EnumeratePowerSources() ()
#15 0x0000000000ea7cd5 in CUPowerSyscall::CUPowerSyscall() ()
#16 0x0000000000ea718e in CConsoleUPowerSyscall::CConsoleUPowerSyscall() ()
#17 0x0000000000c3c79b in ?? ()
#18 0x0000000000c3ddf8 in CPowerManager::Initialize() ()
#19 0x0000000000d2d5d2 in CApplication::Create() ()
#20 0x0000000000dcedfb in XBMC_Run ()
#21 0x000000000076d525 in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
15:41:48 T:140581439760320 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:41:48 T:140581439760320 NOTICE: -----------------------------------------------------------------------
15:41:48 T:140581439760320 NOTICE: Starting Kodi (16.0-ALPHA1 Git:92285ec). Platform: Linux x86 64-bit
15:41:48 T:140581439760320 NOTICE: Using Release Kodi x64 build
15:41:48 T:140581439760320 NOTICE: Kodi compiled Jul 9 2015 by GCC 4.8.4 for Linux x86 64-bit version 3.13.11 (199947)
15:41:48 T:140581439760320 NOTICE: Running on Ubuntu 14.04.2 LTS, kernel: Linux x86 64-bit version 3.13.0-57-generic
15:41:48 T:140581439760320 NOTICE: FFmpeg statically linked, version: 2.6.2-kodi-2.6.2-Isengard-beta
15:41:48 T:140581439760320 NOTICE: Host CPU: Intel® Core™ i3-4130 CPU @ 3.40GHz, 4 cores available
15:41:48 T:140581439760320 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
15:41:48 T:140581439760320 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
15:41:48 T:140581439760320 NOTICE: special://masterprofile/ is mapped to: /home/blacktarzan/.kodi/userdata
15:41:48 T:140581439760320 NOTICE: special://home/ is mapped to: /home/blacktarzan/.kodi
15:41:48 T:140581439760320 NOTICE: special://temp/ is mapped to: /home/blacktarzan/.kodi/temp
15:41:48 T:140581439760320 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
15:41:48 T:140581439760320 NOTICE: Local hostname: BlackTarzan
15:41:48 T:140581439760320 NOTICE: Log File is located: /home/blacktarzan/.kodi/temp/kodi.log
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
this the crash log of what happend
Using very alpha software, what do you expect ?
Wait some days until it's fixed
(2015-07-10, 00:57)nickr Wrote: [ -> ]Using very alpha software, what do you expect ?
I tried to go from alpha to stable but it doesnt work.
"doesn't work" is not a bug report.
(2015-07-10, 01:16)nickr Wrote: [ -> ]"doesn't work" is not a bug report.
I went to kodi linux wiki page... ran the scripts to uninstall kodi...
then i ran the script to install kodi stable version.
but it doesnt open either when i installed it.
Ok what version do you have now? Run
apt-cache policy kodi
(2015-07-10, 01:29)nickr Wrote: [ -> ]Ok what version do you have now? Run
Installed: 2:16.0~git20150709.0200-92285ec-0trusty
Candidate: 2:16.0~git20150709.0200-92285ec-0trusty
Version table:
*** 2:16.0~git20150709.0200-92285ec-0trusty 0
500 http://ppa.launchpad.net/team-xbmc/xbmc-nightly/ubuntu/ trusty/main amd64 Packages
100 /var/lib/dpkg/status
2:15.0~git20150705.1922-rc1-0trusty 0
500 http://ppa.launchpad.net/team-xbmc/unstable/ubuntu/ trusty/main amd64 Packages
2:14.2~git20150327.1058-final-0trusty 0
500 http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ trusty/main amd64 Pac
this is the what came up.
Remove the nightly and unstable repository if you want stable.
(2015-07-10, 01:42)nickr Wrote: [ -> ]Remove the nightly and unstable repository if you want stable.
how so if you dont mind me asking ?
sudo add-apt-repository -r ppa:team-xbmc/unstable
add-apt-repository -r ppa:team-xbmc/xbmc-nightly
Then remove and reinstall kodi
(2015-07-10, 01:55)nickr Wrote: [ -> ]
i did all that then this popped up
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
kodi : Depends: kodi-bin (< 2:14.2~git20150327.1058-final-0trusty.1~) but 2:16.0~git20150709.0200-92285ec-0trusty is to be installed
Depends: libcec2 (>= 2.1.1)
E: Unable to correct problems, you have held broken packages.
sudo apt-get update
sudo apt-get install kodi
sudo apt-get dist-upgrade
(2015-07-10, 01:12)ilovechi23 Wrote: [ -> ]
It doesnt work because the userdata (wiki) more specifically guisettings.xml is borked remove it and install v15 or a 3 day older version of v16
