Full Version: kodi don't start
i use linux mint 17.2 two days a go my kodi doesn’t start .this is the log crash .help please:
=====> Core file: /home/othman/core (2015-07-10 03:07:53.450512297 +0200)
[New LWP 3776]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x0000000000faa4ac in CVariant::cleanup() ()
mod edit: log spam removed
this should be fixed in git master.
i seem to have a similar problem...
here's the log: http://pastebin.com/eYeg2hS4
crashlog: http://pastebin.com/UjUr6wHz
i saw i updated the linux version on the same moment: from 17.1 to 17.2, with a lot of other things attached like firmware, grub, mintdrivers....
so maybe thats the cause. but if so can somebody point me in the right direction to fix this?
thank you very much
search for new updates on linux... found new version of kodi 16.0.
installed it. fixed
so fast the kodi guys to fix issues Smile
for me you can close this thread
solved Wink
cheers
