Full Version: Migration Macbook pro to Macbook pro
Quick question, I'm buying a new MacBook Pro and I would like to migrate my Kodi data (Skin config, playlists, library, addons, sttings) into the new system.
Should I just copy past the current Kodi folder located into library/applicationsupport/Kodi ? (2.6gb)
What the best way in order to have a smooth transition?
If you're migrating from another Mac, you need to install Kodi and then copy the contents of the Kodi folder located at:
~/Library/Application Support/Kodi
It's hidden, so from Finder, pull down the Go menu and select Go To Folder. Paste in the location.
(2015-07-10, 19:17)wgstarks Wrote: [ -> ]If you're migrating from another Mac, you need to install Kodi and then copy the contents of the Kodi folder located at:
Great, it's what I thought thanks
