(2015-12-16, 19:00)ilovethakush Wrote: [ -> ]I take that back.
Super high fan speed on wake is back for the chromebox on the latest build
I dropped the "fan speed" patches as I was assured those would land in 4.4-rc5 or 4.4 would fix that otherwise.
@MattDevo: Can you comment please?
ilovethakush see the chromebox wiki here is a fix.
(2015-12-16, 21:57)fritsch Wrote: [ -> ] (2015-12-16, 19:00)ilovethakush Wrote: [ -> ]I take that back.
@ilovethakush see the chromebox wiki here is a fix.
fritsch, confirmed that build 20151215204732-r21604-g17e2400 has the fan speed issue; apparently the patches didn't make it in yet
(2015-12-17, 09:55)Matt Devo Wrote: [ -> ] (2015-12-16, 21:57)fritsch Wrote: [ -> ] (2015-12-16, 19:00)ilovethakush Wrote: [ -> ]I take that back.
Oki - I will readd them - if you find time before me - a PR would be welcome.
(2015-12-17, 10:01)fritsch Wrote: [ -> ]Oki - I will readd them - if you find time before me - a PR would be welcome.
I'll need to rebase the patches most likely - against your jarvis-egl branch (and kernel 4.4-rc5) I presume?
Yes - that would be fine.
(2015-12-17, 10:46)fritsch Wrote: [ -> ]Yes - that would be fine.
ok, will try to do this tomorrow
Hi!
I got a warning when I tried to do the steps of this tutorial.
In this step:
Allow "everyone" to start the Xserver
sudo dpkg-reconfigure x11-common
the result:
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
invoke-rc.d: Unit x11-common.service is masked
what could I do?
up:
ubuntu server 15.10 64 bit, N3150 motherboard
(2015-12-17, 22:50)zserrbo Wrote: [ -> ]Hi!
In this step:
the result:
what could I do?
Nothing - continue. If you don't run 15.10 but 16.04 you are on your own.
I installed Ubuntu server 15.10. So I continue it. Thanks.
PR submitted, had to tweak the one patch slightly. Also updated the xbox controller patch as well.
Merged - and rebuild. libva / libva-driver-intel bumped to 1.6.2 - no relevant changes for supported hardware.
(2015-12-17, 23:43)fritsch Wrote: [ -> ]Merged - and rebuild. libva / libva-driver-intel bumped to 1.6.2 - no relevant changes for supported hardware.
fan speed fix confirmed for build 20151217223510-r21608-g78f9680
I'll still test builds once in a while because I want to help out and I appreciate all the work you guys are doing.
However, most of the time, I just want to come home and watch some tv without messing with testing and or settings or anything, so I'm just going to run the Isengard 6.0.98 version until Jarvis officially comes out, at which time I hope someone will make a new stable build, supported or not, doesn't matter.
Official Jarvis won't have anything EGL related from this thread.
Yeah I know. I meant, I hope you or someone will make an openelec build with EGL/Jarvis, the same way you did for Isengard
