Running this build on a Intel NUC D54250WYK on a ssd with 9 gigs of ram.
Totally overpowered, but I have so much faith in Kodi I thought it was logical ^_^
I'll check it out after work tomorrow, Yes I'm working on Xmas eve in the USA.
IT dept never sleeps...
With the newest OE-build, I have a very high cpu usage (>60%) (in the menus), with my Pentium G4400 (Skylake)
Congratulations!
Edit: That means you either buy everyone in this thread a skylake or you start posting a
Debug Log - in your case even an output of a thread wise ps - to see which thread has high load.
(2015-12-23, 19:43)FernetMenta Wrote: [ -> ]when did it break?
I've tried all fritsch's builds since 28 nov, unfortunately none of them fixed the issue.
@Milhouse: All your passthrough stuff is fixed and (still) working? Any reports from the other thread with sync problems?
@fritsch: i have partially also problems with sync. i have reported it already. often audio video sync is driften away by time. i can see this in the codec info. when audio/video are more than 7 sec async a rebuffer occures and then the game starts again. to prevent this i have to rezapp or change the audio channel. after that it will stay in sync.
(2015-12-24, 14:54)the-dreamer Wrote: [ -> ]@fritsch: i have partially also problems with sync. i have reported it already. often audio video sync is driften away by time. i can see this in the codec info. when audio/video are more than 7 sec async a rebuffer occures and then the game starts again. to prevent this i have to rezapp or change the audio channel. after that it will stay in sync.
As you use "TearFree" mode - I suspected something like that ... after I have seen what it causes for 25 fps content. Btw. that's no solution that you have there ... post a
Debug Log ... (7 (!) seconds audio off sucks).
(2015-12-24, 14:39)FernetMenta Wrote: [ -> ] (2015-12-24, 14:28)sat4all Wrote: [ -> ] (2015-12-23, 19:43)FernetMenta Wrote: [ -> ]when did it break?
hmm, last thing I heard was that it was fixed: https://github.com/FernetMenta/xbmc/issu...-163300941
OK i'm starting to suspect my stuff, so i've done a hard reset..nothing have changed.
Let's wait for Milhouse confirmation.
generally it works! btw. i don't want to discuss why it is disabled but no passthrough for tv feels like a k.o. for kodi & TV.
is disabling passthrough a temporary solution only?
edit: fritsch could tell better which version i am runing. it is his version r21616
(2015-12-24, 15:53)the-dreamer Wrote: [ -> ]generally it works! btw. i don't want to discuss why it is disabled but no passthrough for tv feels like a k.o. for kodi & TV.
Everything fernet has I ship. Nothing reverted. Last build was from yesterdays with jjslegacy in name.
@FernetMenta:
https://github.com/fritsch/OpenELEC.tv/c...jarvis-egl <- those bump commits reference your latest master hash, I did: 08f2332 two days ago. As you fast forward - don't complain that you don't know what is in - we all don't know - as I hard reset on yours.
