ok, well the guide is written for 16.04. i realize some people use a newer version nowadays. i don't have any problems, just wanted to make sure my system is compliant with the instructions so i can legitimately report problems :-)
perhaps add a short caveat before that section of the setup guide: "if you're using ubuntu 17.whatever, then symlink this etc." ?
hey fritsch,
just a little questions about Kodi visualization on ubuntu : I installed it by : sudo apt install kodi-visualization-spectrum
But doesn't run :
Quote:15:47:07.898 T:139837778061056 DEBUG: Thread Timer 139837778061056 terminating15:47:07.898 T:139839624905344 DEBUG: FreeVisualisation() done15:47:07.898 T:139839624905344 DEBUG: ADDON: Dll Initializing - Spectrum15:47:07.898 T:139839624905344 DEBUG: SECTION:LoadDLL(/usr/lib/x86_64-linux-gnu/kodi/addons/visualization.spectrum/visualization.spectrum.so.1.1.1)15:47:07.898 T:139839624905344 DEBUG: Loading: /usr/lib/x86_64-linux-gnu/kodi/addons/visualization.spectrum/visualization.spectrum.so.1.1.115:47:07.900 T:139839624905344 WARNING: Unable to resolve: visualization.spectrum.so.1.1.1 ADDON_GetTypeVersion, reason: /usr/lib/x86_64-linux-gnu/kodi/addons/visualization.spectrum/visualization.spectrum.so.1.1.1: undefined symbol: ADDON_GetTypeVersion15:47:07.900 T:139839624905344 ERROR: Unable to resolve exports from dll /usr/lib/x86_64-linux-gnu/kodi/addons/visualization.spectrum/visualization.spectrum.so.1.1.115:47:07.900 T:139839624905344 DEBUG: SECTION:UnloadDll(/usr/lib/x86_64-linux-gnu/kodi/addons/visualization.spectrum/visualization.spectrum.so.1.1.1)15:47:07.900 T:139839624905344 ERROR: IAddonInstanceHandler::CreateInstance: visualization.spectrum returned bad status "Permanent failure" during instance creation15:47:07.900 T:139839624905344 FATAL: Visualization: failed to create instance for 'visualization.spectrum' and not usable!15:47:07.903 T:139839080584960 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
I looked on the forum but it doesn't mention anyone
how can I fix?
(2018-04-08, 15:49)Rumpelstiltskin Wrote: [ -> ]hey fritsch,
But doesn't run :
how can I fix?
Please - put your "just a little question" posts into their own thread. No one will ever find them again in here. I know the problem, but won't post it in here out of that reason.
you're absolutely right, I apologize
For anyone using this guide that has an MCE IR remote this thread;
https://forum.kodi.tv/showthread.php?tid=326366
Provides an ir-keytable that greatly improves ease of setup. All keys on MCE remotes are configured.
Install is easy;
1) remove LIRC
2) install ir-keytable
3) create /etc/rc_keymaps directory
4) copy the rc6-mce config file from github to rc_keymaps
5) sudo ir-keytable -c -w /etc/rc_keymaps/rc6_mce
Remote will then work without issue, as long as your receiver is already working of course.
Disable DPMS, don't cut logfiles.
(2018-04-14, 10:41)fritsch Wrote: [ -> ]Disable DPMS, don't cut logfiles.
i disabled it with xfce4-power-manager but the problem still remain
Do u need a full log?
xsetroot #000000
xset -dpms
OUTPUT=`xrandr -display :0 -q | sed '/ connected/!d;s/ .*//;q'`
xrandr -display :0 --output $OUTPUT --set "Broadcast RGB" "Full"
/usr/bin/kodi --standalone
openbox --exit
Use this as your autostart file.
Then I have no idea. If kodi's internal power management settings are disabled.
Thanks for the excellent how-to.
One question: the systemd service does not seem to respond to a stop command.
What is the recommended way to stop or restart kodi from SSH or the CLI?
(2018-04-14, 23:27)wouterbaake Wrote: [ -> ]Thanks for the excellent how-to.
That should work. Might be for you kodi hangs on exit or it crashes while exit and systemd restarts it. A
Debug Log after the stop command will help.
