(2018-04-14, 09:48)Rumpelstiltskin Wrote: [ -> ]Hi,
when I listen to music after about 10 minutes, the tv and audio turn off, here's the log
https://pastebin.com/tVNiskFF
What can be wrong?
Make sure that Kodi uses not the OS screensaver. Try one that comes with kodi like black or dim
(2018-04-14, 23:27)wouterbaake Wrote: [ -> ]Thanks for the excellent how-to.
One question: the systemd service does not seem to respond to a stop command.
What is the recommended way to stop or restart kodi from SSH or the CLI?
U can try to stop it by : sudo service kodi stop
(2018-04-15, 15:54)FernetMenta Wrote: [ -> ] (2018-04-14, 09:48)Rumpelstiltskin Wrote: [ -> ]Hi,
What can be wrong?
With the dim run fine !!! It works fine but I wish I could see the screen if possibile
Hi guys,
just wanted to share with you my joy: look what is just arrived (at last)
I'm spending the evening to install ubuntu 18.04 (server so I try it) then if you have any questions, I'm here
Hey @
fritsch @yol
Another "problem" : if I switch from HDMI3 (kodi) to HDMI1 (sky) and return in Kodi, I lost the signal.
When I lost the signal : stop kodi service and start kodi service and kodi turn on but without audio.
I must reboot the system to obtain audio + video working again
here the
LOG
What could be?
(2018-04-30, 10:29)Rumpelstiltskin Wrote: [ -> ]Hey @fritsch @yol
here the LOG
What could be?
Fixate the EDID. Switching outputs means, you tell the Linux-Box that no TV is attached anymore ... as a workaround hard code the EDID via drm_kms_helper
Thanks for ur replay,
I followed your guide at post
1793
I have two hdmi output, one is linked into HDMI3 in my TV and the second in BD-DVD in my onkyo.
This is the output for ls -la in
/sys/class/drm/card0*
i tried :
/sys/class/drm/card0-HDMI-A-1/edid
and
2/edid
cat /etc/initramfs-tools/hooks/include-edid-data | pastebinit
Do you have another idea to advise me
One more thing : when i do sudo update-initramfs -u i get this strange warning :
Quote:@nucbox:~$ sudo update-initramfs -u
update-initramfs: Generating /boot/initrd.img-4.16.3-041603-generic
I: The initramfs will attempt to resume from /dev/sdc3
I: (UUID=cca4de02-4a74-11e8-b920-94c6911ca100)
I: Set the RESUME variable to override this.
I attach the dmesg
LOG
I'd say: Use LibreELEC :-)
Even you follow my howto, you did most things terribly wrong, hehe - even the grub entry is not existent.
The error with the resume is wrong UUID in
cat /etc/initramfs-tools/conf.d/resume
RESUME=UUID=810a43dd-fec0-4d77-91ca-f79f5b7d76e5
Make sure it matches your swap partition, e.g.
[code]fritsch@t440s:~$ sudo blkid
/dev/sda1: UUID="73BD-BA00" TYPE="vfat" PARTUUID="5b4b8aad-1238-4946-bee4-706ab64f7105"
/dev/sda2: UUID="25223c2c-2ab1-4c6c-add6-52eccf56756f" TYPE="ext4" PARTUUID="ad6c2e7a-6d2c-4bb6-9bd8-d1f11956f771"
/dev/sda3: UUID="8bf0674a-ec41-4f0c-9d0d-5bc0bcb06148" TYPE="ext4" PARTUUID="b67884ac-cafe-4771-8e8e-5d7d5485a5cf"
/dev/sda4: UUID="d26a038b-9b6c-4f3a-9e77-30ecfba61a47" TYPE="swap" PARTUUID="810a43dd-fec0-4d77-91ca-f79f5b7d76e5" <- See the SWAP line and it's UUID
I've tried following the 16.04 guide, but using 18.04 and Leia, and a couple of observations.
1. Without pinning, ubuntu gets in a mess at the install of kodi and kodi-bin, it seems to take some "kodi" things from the ubuntu repo and some from the nightly ppa. After a few times hitting the same roadblock, I renamed sources.list while installing leia, then changed it back afterwards (pinning looked too much work for a small problem) --edit adding v17 ppa didn't have this issue
2. Probably expected, but libnfs8 libva1 (should I add the xenial repo?) python-software-properties are not found\wrong for 18.04
3. Lirc doesn't work as it did under 16.04, I removed it and let the kernel driver take over, but am having a few keymap issues -- edit
https://forum.kodi.tv/showthread.php?tid=326366 was the answer
Obviously the guide is not written for either products I'm trying to install, so feel free to take the piss out of me for trying, or point out where I'm being an idiot.... Particularly if there is something obvious around using an HP MCE remote and fintec receiver I'm missing....
Do I need to do anything extra for Gemini Lake ? Use 18.04 and the latest kernel ? Had a quick go last night and there was no display so I tried Librelec and that worked fine (latest nightly)
(2018-05-04, 18:07)luna_s Wrote: [ -> ]Do I need to do anything extra for Gemini Lake ? Use 18.04 and the latest kernel ? Had a quick go last night and there was no display so I tried Librelec and that worked fine (latest nightly)
Nobody knows - cause your "quick test" on "your hardware that only you have" did not include posting the required logfiles this thread kindly asks for.
