Full Version: Vu+ Duo2 - no pvr add-ons could be found
I have a Vu+ Duo2 box running the Openvix image. I installed Kodi, which is available as a plugin.
Kodi runs fine, but I get the message 'no pvr add-ons could be found' when I try to enable Live TV.
Do I need to download the PVR add ons and install them manually? I can't see any PVR options when I try the get add ons option within Kodi.
Any help would be much appreciated as l'm not sure what to do next.
Thanks,
Andy
you can't use the PVR Plugin when you use Kodi at your Duo2. Kodi on Vu+ is very alpha Smile
