2006-11-17, 21:05
2006-11-17, 21:07
Wow fantastic! Great help to skin and python developers everywhere!
Who did the development work on this? They deserve kudos from every skin and python dev here
Thanks guys!
Thanks guys!
2006-11-17, 22:05
won't work for me.
I think its cuz I am currently using a horrible Matrox 4MB PCI video card from 1996. I tried to set up debug mode logging via AdvancedSettings.
here's my log output:
12:00:35 M:695537664 NOTICE: -----------------------------------------------------------------------
12:00:35 M:695517184 NOTICE: Starting XBoxMediaCenter. Built on Nov 17 2006
12:00:35 M:695517184 NOTICE: Q is mapped to: \XBMC
12:00:35 M:695517184 NOTICE: Log File is located: Q:\xbmc.log
12:00:35 M:695517184 NOTICE: -----------------------------------------------------------------------
12:00:35 M:695410688 NOTICE: Setup DirectX
12:00:35 M:694980608 NOTICE: load settings...
12:00:35 M:694972416 NOTICE: loading T:\guisettings.xml
12:00:35 M:694951936 ERROR: Unable to load T:\guisettings.xml, creating new T:\guisettings.xml with default values
12:00:35 M:694820864 NOTICE: Saving Unknown settings in T:\avpacksettings.xml
12:00:35 M:694763520 NOTICE: Saving Unknown settings in T:\avpacksettings.xml
12:00:35 M:694697984 NOTICE: Getting hardware information now...
12:00:35 M:694697984 NOTICE: Checking resolution 10
12:00:35 M:694697984 NOTICE: Setting autoresolution mode 6
12:00:35 M:694693888 NOTICE: Per AV pack settings are on
12:00:35 M:694693888 NOTICE: Unknown found : loading T:\avpacksettings.xml
12:00:35 M:694689792 NOTICE: Getting hardware information now...
12:00:35 M:694681600 NOTICE: Checking resolution 10
12:00:35 M:694681600 NOTICE: Setting autoresolution mode 6
12:00:35 M:694693888 NOTICE: q:\userdata\sources.xml
12:00:35 M:694685696 WARNING: Emergency recovery console starting...
it hangs. This means my video card can't do the DirectX stuff that is called for by the program right? I have P,Q,T, and Z subst'ed correctly, and my logs are being written to my Q: location.
2006-11-17, 23:37
Do you need sp2? Or .net framework?
2006-11-18, 02:14
Just wanting to say a big THANKS!! what an relife to do python scripts now
2006-11-18, 02:52
SleepyP:
It could be, but it could just as easily be something else. Enable full debuglogging via advancedsettings.xml to see if there's anything else available in the logs.
mbay:
It does not require the .net framework, nor does it require service pack 2. All you need is directx 8 or later.
And yeah, I ported it - glad you like it
Cheers
Jonathan
mbay:
Cheers
Jonathan
2006-11-18, 03:25
I am getting nothing but freezing issues no matter what combination i am using.
Would it be possible for someone to map out how it should be set up on the pc?
Currently the folder i have containing xbmc is located on my desktop. The only thing i havent done is
subst q: c:\xbmc_pc
subst t: q:\userdata
subst p: q:\userdata
subst z: c:\xbmc_pc\cache
Honestly that's where i am lost which is where i am sure to be going wrong. Any help would be greatful.
subst q: c:\xbmc_pc
2006-11-18, 03:40
Have you read the readme that came with it? It sums it up quite well I think - if not, please let me know which part you didn't understand.
Have you executed the script that was named "run_me_first.bat"?
Open a command prompt and type "subst" to check that the drives are mapped.
Cheers,
Jonathan
Cheers,
Jonathan
2006-11-18, 03:50
What should i be seeing once i run subst?
Also what should be the layout of the folder xbmc is in?
2006-11-18, 04:07
19:00:55 M:168792064 NOTICE: -----------------------------------------------------------------------
19:00:55 M:168771584 NOTICE: Starting XBoxMediaCenter. Built on Nov 17 2006
19:00:55 M:168771584 NOTICE: Q is mapped to: C:\Users\Adam Wood\Desktop\XBMC_PC_rev7133\XBMC_PC_rev7133
19:00:55 M:168771584 NOTICE: Log File is located: Q:\xbmc.log
19:00:55 M:168771584 NOTICE: -----------------------------------------------------------------------
19:00:55 M:168628224 NOTICE: Setup DirectX
19:00:57 M:166174720 NOTICE: load settings...
19:00:57 M:166166528 NOTICE: loading T:\guisettings.xml
19:00:57 M:166146048 ERROR: Unable to load T:\guisettings.xml, creating new T:\guisettings.xml with default values
19:00:57 M:165994496 NOTICE: Saving Unknown settings in T:\avpacksettings.xml
19:00:57 M:165912576 ERROR: Unable to save settings to T:\guisettings.xml
19:00:57 M:165912576 ERROR: XFILE::CFile:elete - Error deleting file T:\guisettings.xml
19:00:57 M:165912576 NOTICE: Saving Unknown settings in T:\avpacksettings.xml
19:00:57 M:165908480 WARNING: Emergency recovery console starting...
That is what i am seeing in the log.
2006-11-18, 04:56
Loaded Gun Wrote:What should i be seeing once i run subst?
once you run the bat file you should see 4 nnew drives in explorer and clicking on q: should take you straight to the xbmc dir
Also if you guys are running vista it just may not work its not been tested on it
2006-11-18, 04:57
You may have problems if you already have a p,q,t or z drive.
the above shouldn't require any changes. This also deletes the subst after you exit xbmc_pc.exe.
Just save it as xbmc_pc.bat and put it in the same folder as xbmc_pc.exe. Then run it.
subst q: .
md q:\cache
subst z: q:\cache
xbmc_pc.exe
subst p: /d
subst t: /d
subst z: /d
rd /s /q q:\cache
subst q: /d
CademiaX
2006-11-18, 05:05
jmarshall: Ok, I compile my own build of the exe and grabbed the one you compiled, my question is, how did you disable the fps/free mem?
and I have notice some issues when I switch between apps, I will minimize it and bring it back up and when i click on it to reactive the mouse it treats it as if Im right clicking.. is that something Im doing wrong or something else?
2006-11-18, 05:29
CademiaX Wrote:jmarshall: Ok, I compile my own build of the exe and grabbed the one you compiled, my question is, how did you disable the fps/free mem?dont compile it in debug mode compile it in release mode
2006-11-18, 05:46
How do I un-map the drives that the bat maps?
