Full Version: XBMC_PC Win32 GUI Development Environment for skinners (skin developers)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
Quote:A little over a month ago, I was away from home without the xbox and still wanted to get some development done. To solve this problem, I decided to port parts of XBMC to the PC.
Now, before everyone starts getting too excited, let's make some things clear:
1. It's not a full port, nor is it planned to be a full port. We are not planning on abandoning the xbox anytime soon.
2. With that said, most stuff works - at least stuff useful for the target audience.
3. It's designed primarily for skinners and python developers who can test out their skins and scripts without having to transfer everything to the xbox.
Okay, so with that out of the way, what is it?
Basically, it's a simple port of the majority of XBMC. This includes the entire gui system, file listing, some of the filesystem code (eg local, database files, zip + rar etc.), very simple audio playback, slideshows, python scripts and so on. Video playback is not supported, nor are screensavers or visualisations (basically anything that was relying on the xbox version of directx).
The source code is available in SVN and requires the directx sdk (I use the Summer 2004 version) installed to build the executable. You do not require the XDK. The executable that it produces may be distributed freely - it contains no XDK code whatsoever.
To run it, you basically just grab a full build of the usual xbox version of XBMC, place it somewhere on your PC, and replace the .xbe with XBMC_PC.exe. Note that you'll need a DirectX 8 compatible machine. Most graphics cards nowadays should be fine, but some older chipsets may have issues.
You then have to mount some drives so that the executable knows where to find stuff. You use the subst command under DOS to do so. I use the following .bat file:
subst q: c:\xbmc_pc
subst t: q:\userdata
subst p: q:\userdata
subst z: c:\xbmc_pc\cache
Obviously you just change the location of q: and z: to reflect wherever you want them. Note that p: is the "profile" directory, and should point to your profile folder if you are not the master user.
That's about it. It logs exactly the same as XBMC does, so if you get errors, it's likely logged about them.
We're not supporting general users running this to play their mp3's or whatever - but we'll be happy to help get skinners and python devs up and running, as that is the target audience.
Ofcourse, others may feel free to have a play all they like. If there's any Win32 developers listening in, then you are free to download the source from SVN and help extend it in anyway you like. One immediate improvement would be to have the executable auto-mount the drives it needs.
Discuss this announcement here.
Wow, very nice idea. That was the only thing why i stopped workin on XBMC-Plug-ins!! Skinning is a hard job! Angry
Quote: You do not require the XDK. The executable that it produces may be distributed freely - it contains no XDK code whatsoever.
Did somebody compiled that exe already?
wow! the DX SDK is like 500 MB! ETA on my horrible wireless connection is 3 hours Sad Sad Sad
Thanks for this jmarshall! This should speed up dev time on scripts and scripts. I know it will help me out a lot. Thanks again.
Grab the latest revision straight from SVN here:
http://www.xboxmediacenter.com/XBMC_PC_rev7133.rar
Read the readme that is contained for how to install/run.
Cheers,
Jonathan
Hi!
I want to use this to build themes and skins for xbmc.
when I use a full build and replace the xbe with the exe and run the .bat file as per the coding above, all I get when i launch the exe is a black, frozen app.
I made sure I downloaded the latest version of directx, but I think I'm missing something.
Any help is greatly appreciated.
mbay after you run the bat you should then have drives for q: p: t: and z: in windows explorer if they are not there then thats a good start for the problem
great idea jmarshall. il will sure enjoy this.
it works great
but how do you click some buttons, like the b button?
nevermind i found it: its backspace
I suspect this port doesn't work on linux?
no.
a shame...
hehe there's no DirectX on Linux Smile
Hey, I'm the guy who wrote the XM Radio script last year and I've been wanting to update it, but don't feel like going through all the *fun* associated with ftping over and over and over.
So, before I install this.. Does anyone know if it supports streaming WMA?
I guess I could implement the gui and other parts and just implement the streaming once I get the gui written.
Just wondering.
