2015-07-17, 16:34
Bought a fire tv to run Kodi but after following the install instructions Kodi crashes a few seconds after launching. It seems as if it is running faintly in the background behind the launch application screen. Have tried a couple of versions of Kodi and also updated the aftv to latest firmware but no difference.After I've tried to run it once it wont even start. If I clear cache and data and force stop it then tries to start, telling you its the first time but crashes again. Any ideas, its probably something simple I've missed. Loaded firestarter using same technique and it seems to work fine. Thanks in advance.
