2015-07-17, 21:40
Hey guys,
I'm running into an issue where Kodi starts to freeze after a few minutes of use. I've copied the log file below. It's a bit long, but if anyone has seen this before, and knows how to solve it, please help! Thanks!
11:51:06 T:1781277528 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:51:06 T:1781277528 NOTICE: -----------------------------------------------------------------------
11:51:06 T:1781277528 NOTICE: Starting Kodi (14.1 Git:2015-01-30-38e4046-dirty). Platform: Android ARM 32-bit
11:51:06 T:1781277528 NOTICE: Using Release Kodi x32 build
11:51:06 T:1781277528 NOTICE: Kodi compiled Jan 30 2015 by GCC 4.8.0 for Android ARM 32-bit API level 14 (API level 14)
11:51:06 T:1781277528 NOTICE: Running on MBX Quad-Core Enjoy TV Box with Android 4.4.2 API level 19, kernel: Linux ARM 32-bit version 3.10.33
11:51:06 T:1781277528 NOTICE: FFmpeg version: 14.0-Helix-87-g38e4046-xbmc-2.4.6-Helix
11:51:06 T:1781277528 NOTICE: Host CPU: ARMv7 Processor rev 1 (v7l), 2 cores available
11:51:06 T:1781277528 NOTICE: Product: stvm8, Device: stvm8, Board: stvm8 - Manufacturer: MBX, Brand: MBX, Model: Quad-Core Enjoy TV Box, Hardware: amlogic
11:51:06 T:1781277528 NOTICE: ARM Features: Neon enabled
11:51:06 T:1781277528 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
11:51:06 T:1781277528 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
11:51:06 T:1781277528 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
11:51:06 T:1781277528 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
11:51:06 T:1781277528 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
11:51:06 T:1781277528 NOTICE: The executable running is:
11:51:06 T:1781277528 NOTICE: Local hostname: localhost
11:51:06 T:1781277528 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
11:51:06 T:1781277528 NOTICE: load settings...
11:51:06 T:1781277528 DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 19
11:51:06 T:1781277528 NOTICE: aml_present, rtn(0)
11:51:06 T:1781277528 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
11:51:06 T:1781277528 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
11:51:06 T:1781277528 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
11:51:06 T:1781277528 NOTICE: Found 1 Lists of Devices
11:51:06 T:1781277528 NOTICE: Enumerated AUDIOTRACK devices:
11:51:06 T:1781277528 NOTICE: Device 1
11:51:06 T:1781277528 NOTICE: m_deviceName : AudioTrack
11:51:06 T:1781277528 NOTICE: m_displayName : android
11:51:06 T:1781277528 NOTICE: m_displayNameExtra: audiotrack
11:51:06 T:1781277528 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:51:06 T:1781277528 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
11:51:06 T:1781277528 NOTICE: m_sampleRates : 48000
11:51:06 T:1781277528 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
11:51:06 T:1781277528 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:51:06 T:1781277528 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:51:06 T:1781277528 NOTICE: Default DVD Player: dvdplayer
11:51:06 T:1781277528 NOTICE: Default Video Player: dvdplayer
11:51:06 T:1781277528 NOTICE: Default Audio Player: paplayer
11:51:06 T:1781277528 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:51:06 T:1781277528 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
11:51:06 T:1781277528 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:51:06 T:1781277528 NOTICE: Loaded playercorefactory configuration
11:51:06 T:1781277528 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:51:06 T:1781277528 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:51:06 T:1800235184 NOTICE: Thread ActiveAE start, auto delete: false
11:51:06 T:1800053032 NOTICE: Thread AESink start, auto delete: false
11:51:06 T:1781277528 NOTICE: Running database version Addons16
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.wareztuga
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.japanese
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.xunitytalk
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.fightnight
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.Rodrigo
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.popey
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.googlecode.xbmc-addons
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.kodi-czsk
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.xbmc-repo-agx
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.divingmule.addons
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.mash2k3
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.googlecode.kozz-addons
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.FTV-Guide-Repo
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.carb0s
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.aj-addons
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.sd-xbmc.org
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.arabic.xbmc-addons
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.MisterX
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.Vinnydude
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.BlazeRepo
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.rasjanisrepo.xbmc
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.t0mm0
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.p2p-streams.xbmc
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.cocawe
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.TheHighwaysEasyInstallRepo
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.googlecode.apple-tv2-xbmc
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.Jas0npc
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.smoothstreams
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.googlecode.anarchintosh-projects
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.angelscry.xbmc-plugins
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.TheYidXXX
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.xbmcadult
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.tknorris.release
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.xbmc.doplnky
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.Kinkin
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.CanadaOnDemand
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.eldorado
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.StreamOn
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.xbmchub
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.MovK.xbmc
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.entertainmentrepo
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.googlecode.xbmc-addons-chinese
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.whufclee
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.passion.xbmc.org.frodo
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.bstrdsmkr
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.xbmc.org
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.bluecop.xbmc-plugins
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.xbmc-israel
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.MaxMustermann.xbmc
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.lambda
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.googlecode.sparetime
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.Dixie-Deans-XBMC-Repo
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.The_Silencer
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.pvr-android.xbmc.org
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.xbmc.tvm
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.SportsDevil
11:51:07 T:1781277528 NOTICE: ADDONS: Using repository repository.dk-xbmc-repaddon
11:51:07 T:1781277528 ERROR: Unable to load libcec.so, reason: (null)
11:51:07 T:1781277528 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
11:51:07 T:1807283480 NOTICE: Thread PeripBusUSB start, auto delete: false
11:51:07 T:1781277528 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
11:51:07 T:1781277528 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
11:51:07 T:1781277528 NOTICE: Previous line repeats 1 times.
11:51:07 T:1781277528 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
11:51:07 T:1781277528 NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
11:51:07 T:1781277528 NOTICE: Checking resolution 16
11:51:07 T:1781277528 NOTICE: GL_VENDOR = ARM
11:51:07 T:1781277528 NOTICE: GL_RENDERER = Mali-450 MP
11:51:07 T:1781277528 NOTICE: GL_VERSION = OpenGL ES 2.0
11:51:07 T:1781277528 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
11:51:07 T:1781277528 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
11:51:07 T:1781277528 NOTICE: No Joystick name specified, loading default map
11:51:07 T:1781277528 NOTICE: Previous line repeats 36 times.
11:51:07 T:1781277528 NOTICE: Running database version Addons16
11:51:07 T:1781277528 NOTICE: Running database version ViewModes6
11:51:07 T:1781277528 NOTICE: Running database version Textures13
11:51:07 T:1781277528 NOTICE: Running database version MyMusic48
11:51:07 T:1781277528 NOTICE: Running database version MyVideos90
11:51:07 T:1781277528 NOTICE: Running database version TV26
11:51:07 T:1781277528 NOTICE: Running database version Epg8
11:51:08 T:1781277528 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
11:51:08 T:1781277528 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
11:51:08 T:1781277528 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
11:51:08 T:1781277528 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:51:08 T:1835662520 NOTICE: Thread LanguageInvoker start, auto delete: false
11:51:08 T:1781277528 NOTICE: Previous line repeats 12 times.
11:51:08 T:1781277528 NOTICE: initialize done
11:51:08 T:1781277528 NOTICE: Running the application...
11:51:09 T:1837081088 NOTICE: -->Python Interpreter Initialized<--
11:51:09 T:1853491128 NOTICE: Thread JobWorker start, auto delete: true
11:51:09 T:1845893664 NOTICE: -->Python Interpreter Initialized<--
11:51:09 T:1781277528 NOTICE: Previous line repeats 1 times.
11:51:09 T:1781277528 NOTICE: starting zeroconf publishing
11:51:09 T:1854650568 NOTICE: Thread ZerocconfEmbedded start, auto delete: false
11:51:09 T:1854225832 NOTICE: Thread JobWorker start, auto delete: true
11:51:09 T:1781277528 NOTICE: ES: Starting event server
11:51:09 T:1858868208 NOTICE: Thread EventServer start, auto delete: false
11:51:09 T:1858868208 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:51:09 T:1858868208 NOTICE: UDP: Listening on port 9777
11:51:09 T:1781277528 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
11:51:09 T:1859036504 NOTICE: Thread TCPServer start, auto delete: false
11:51:09 T:1781277528 NOTICE: GL_VENDOR = ARM
11:51:09 T:1781277528 NOTICE: GL_RENDERER = Mali-450 MP
11:51:09 T:1781277528 NOTICE: GL_VERSION = OpenGL ES 2.0
11:51:09 T:1781277528 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
11:51:09 T:1781277528 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
11:51:09 T:1859276112 NOTICE: Thread RSSReader start, auto delete: false
11:51:09 T:1835662520 NOTICE: -->Python Interpreter Initialized<--
11:51:09 T:1853473240 NOTICE: Previous line repeats 2 times.
11:51:09 T:1853473240 NOTICE: Thread LanguageInvoker start, auto delete: false
11:51:09 T:1845879232 NOTICE: -->Python Interpreter Initialized<--
11:51:09 T:1847901256 NOTICE: Previous line repeats 4 times.
11:51:09 T:1847901256 NOTICE: Thread FileCache start, auto delete: false
11:51:09 T:1845898968 NOTICE: -->Python Interpreter Initialized<--
11:51:09 T:1837081088 NOTICE: Started
11:51:09 T:1837188184 NOTICE: -->Python Interpreter Initialized<--
11:51:09 T:1882810456 NOTICE: AxelProxy Downloader Starting - 127.0.0.1:45550
11:51:09 T:1882810456 NOTICE: Press CTL break to stop.....
11:51:09 T:1935019312 NOTICE: Thread FileCache start, auto delete: false
11:51:10 T:1853473240 NOTICE: Previous line repeats 1 times.
11:51:10 T:1853473240 NOTICE: -->Python Interpreter Initialized<--
11:51:10 T:1843186960 NOTICE: Thread AlarmClock start, auto delete: false
11:51:10 T:1857758280 NOTICE: Thread LanguageInvoker start, auto delete: false
11:51:10 T:1859351680 NOTICE: Thread FileCache start, auto delete: false
11:51:11 T:1845898968 NOTICE: Previous line repeats 1 times.
11:51:11 T:1845898968 NOTICE: 1Channel: Service: Installed Version: 2.5.64
11:51:11 T:1845879232 NOTICE: 14
11:51:11 T:1845895104 NOTICE: StorageServer Module loaded RUN
11:51:11 T:1845895104 NOTICE: StorageClient-2.5.4 Starting server
11:51:11 T:1845898968 NOTICE: 1Channel: Loading sqlite3 as DB engine
11:51:11 T:1847623064 NOTICE: Thread FileCache start, auto delete: false
11:51:11 T:1845898968 NOTICE: 1Channel: Service: Resetting...
11:51:11 T:1845898968 NOTICE: 1Channel: Service: starting...
11:51:11 T:1847694304 NOTICE: Thread FileCache start, auto delete: false
11:51:11 T:1857758280 NOTICE: -->Python Interpreter Initialized<--
11:51:11 T:1857758280 WARNING: CPythonInvoker(14): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
11:51:11 T:1935834368 NOTICE: Thread FileCache start, auto delete: false
11:51:12 T:1853473240 NOTICE: Previous line repeats 3 times.
11:51:12 T:1853473240 NOTICE: CommonFunctions-2.5.1
11:51:12 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:13 T:1845879232 NOTICE: Universal - An Addons Toolkit: -watchhistory- -Loading sqlite3 as DB engine version: 3.8.6
11:51:13 T:1845879232 NOTICE: Universal - An Addons Toolkit: - watchhistory - -Auto Cleanup Start
11:51:13 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
11:51:13 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:13 T:1845879232 NOTICE: Universal - An Addons Toolkit: -watchhistory- -DELETE FROM watch_history WHERE lastwatched < '2015-06-27'
11:51:13 T:1845879232 NOTICE: Universal - An Addons Toolkit: - watchhistory - -Auto Cleanup End
11:51:13 T:1857758280 NOTICE: 0 Stale Textures Removed
11:51:13 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:13 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:13 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://gitlab.com/mash2k3/mash2k3-repository/raw/master/addons.xml.md5>
11:51:14 T:1854225832 ERROR: Previous line repeats 1 times.
11:51:14 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
11:51:14 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:14 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:15 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
11:51:15 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:15 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://gitlab.com/mash2k3/mash2k3-repository/raw/master/addons.xml>
11:51:15 T:1854225832 ERROR: Repository All Addons by Mash returned no add-ons, listing may have failed
11:51:15 T:1912380088 NOTICE: Thread FileCache start, auto delete: false
11:51:15 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:15 T:1906610064 ERROR: Previous line repeats 1 times.
11:51:15 T:1906610064 NOTICE: Thread FileCache start, auto delete: false
11:51:16 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:16 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:16 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:16 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:16 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://carb0s-repo.googlecode.com/svn/addons/addons.xml.md5>
11:51:16 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://carb0s-repo.googlecode.com/svn/addons/addons.xml>
11:51:16 T:1854225832 ERROR: Repository Carb0's XBMC Addons returned no add-ons, listing may have failed
11:51:16 T:1910817352 NOTICE: Thread FileCache start, auto delete: false
11:51:17 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:17 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:17 T:1856920336 ERROR: Previous line repeats 1 times.
11:51:17 T:1856920336 NOTICE: Thread FileCache start, auto delete: false
11:51:18 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:18 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:18 T:1842167776 NOTICE: Thread FileCache start, auto delete: false
11:51:18 T:1857758280 NOTICE: Thread FileCache start, auto delete: false
11:51:19 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:19 T:1841754224 NOTICE: Thread FileCache start, auto delete: false
11:51:20 T:1912380088 NOTICE: Thread FileCache start, auto delete: false
11:51:20 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:20 T:1906610064 NOTICE: Thread FileCache start, auto delete: false
11:51:20 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:20 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:20 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:20 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://raw.github.com/cocawe/My-xbmc-repo/master/addons.xml.md5>
11:51:21 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:21 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:21 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:21 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:21 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://raw.github.com/cocawe/My-xbmc-repo/master/addons.xml>
11:51:21 T:1854225832 ERROR: Repository Cocawe's REPO returned no add-ons, listing may have failed
11:51:21 T:1857309024 NOTICE: Thread FileCache start, auto delete: false
11:51:21 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:22 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:22 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:22 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:22 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:22 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://bitbucket.org/jas0npc_13/jas0npc-repo/raw/master/addons.xml.md5>
11:51:23 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:23 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:23 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:23 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:23 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://bitbucket.org/jas0npc_13/jas0npc-repo/raw/master/addons.xml>
11:51:23 T:1854225832 ERROR: Repository Jas0n`s REPO returned no add-ons, listing may have failed
11:51:23 T:1856939272 NOTICE: Thread FileCache start, auto delete: false
11:51:24 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:24 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:24 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
11:51:24 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:25 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
11:51:25 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:25 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://www.gwenael.org/Repository/addons.xml.md5>
11:51:25 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:25 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:26 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
11:51:26 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:26 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://www.gwenael.org/Repository/addons.xml>
11:51:26 T:1854225832 ERROR: Repository Angelscry Repository returned no add-ons, listing may have failed
11:51:26 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:26 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:26 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:27 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:27 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:27 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://bitbucket.org/tcz009/theyidxxx/raw/master/addons.xml.md5>
11:51:27 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:28 T:1854225832 ERROR: Previous line repeats 1 times.
11:51:28 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:28 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:28 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:28 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:28 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://bitbucket.org/tcz009/theyidxxx/raw/master/addons.xml>
11:51:28 T:1854225832 ERROR: Repository TheYid's [COLOR red]Adult[/COLOR] repo returned no add-ons, listing may have failed
11:51:29 T:1839416960 NOTICE: Thread FileCache start, auto delete: false
11:51:29 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:29 T:1905934808 NOTICE: Thread FileCache start, auto delete: false
11:51:30 T:1883329360 NOTICE: Thread FileCache start, auto delete: false
11:51:30 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:30 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:30 T:1935627952 NOTICE: Thread FileCache start, auto delete: false
11:51:31 T:1911051584 NOTICE: Previous line repeats 2 times.
11:51:31 T:1911051584 NOTICE: Thread BackgroundLoader start, auto delete: false
11:51:31 T:1911051584 WARNING: static XFILE::IFile* XFILE::CFileFactory::CreateLoader(const CURL&) - unsupported protocol(script) in script://plugin.video.tvondesizonexl/-poster.jpg
11:51:31 T:1911051584 WARNING: static XFILE::IFile* XFILE::CFileFactory::CreateLoader(const CURL&) - unsupported protocol(script) in script://plugin.video.tvondesizonexl/-poster.png
11:51:31 T:1911051584 WARNING: static XFILE::IFile* XFILE::CFileFactory::CreateLoader(const CURL&) - unsupported protocol(script) in script://plugin.video.tvondesizonexl/-banner.jpg
11:51:31 T:1911051584 WARNING: static XFILE::IFile* XFILE::CFileFactory::CreateLoader(const CURL&) - unsupported protocol(script) in script://plugin.video.tvondesizonexl/-banner.png
11:51:31 T:1911051584 WARNING: static XFILE::IFile* XFILE::CFileFactory::CreateLoader(const CURL&) - unsupported protocol(script) in script://plugin.video.tvondesizonexl/-fanart.jpg
11:51:31 T:1911051584 WARNING: static XFILE::IFile* XFILE::CFileFactory::CreateLoader(const CURL&) - unsupported protocol(script) in script://fanart.jpg/
11:51:31 T:1911051584 WARNING: static XFILE::IFile* XFILE::CFileFactory::CreateLoader(const CURL&) - unsupported protocol(script) in script://plugin.video.tvondesizonexl/-fanart.png
11:51:31 T:1911051584 WARNING: static XFILE::IFile* XFILE::CFileFactory::CreateLoader(const CURL&) - unsupported protocol(script) in script://fanart.png/
11:51:31 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:32 T:1910232488 ERROR: Previous line repeats 1 times.
11:51:32 T:1910232488 NOTICE: Thread FileCache start, auto delete: false
11:51:32 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:33 T:1854225832 ERROR: Previous line repeats 1 times.
11:51:33 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:33 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:33 T:1910788424 NOTICE: Thread JobWorker start, auto delete: true
11:51:33 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:33 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:33 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://dl.dropbox.com/u/57491593/repo1/addons.xml.md5>
11:51:34 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:34 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:34 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:35 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:35 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:35 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <https://dl.dropbox.com/u/57491593/repo1/addons.xml>
11:51:35 T:1854225832 ERROR: Repository StreamOn's add-ons returned no add-ons, listing may have failed
11:51:35 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:35 T:1854106240 NOTICE: Thread FileCache start, auto delete: false
11:51:35 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:36 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:36 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:36 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:36 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:36 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://movk-xbmc-addon.googlecode.com/svn/addons.xml.md5>
11:51:36 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://movk-xbmc-addon.googlecode.com/svn/addons.xml>
11:51:36 T:1854225832 ERROR: Repository MovK repository returned no add-ons, listing may have failed
11:51:37 T:1855366440 NOTICE: Thread FileCache start, auto delete: false
11:51:37 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:37 T:1835785400 NOTICE: Thread FileCache start, auto delete: false
11:51:37 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:37 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:37 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:37 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:37 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://whufclee.googlecode.com/svn/repo/addons.xml.md5>
11:51:38 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:38 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:38 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:38 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:38 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://whufclee.googlecode.com/svn/repo/addons.xml>
11:51:38 T:1854225832 ERROR: Repository whufclee Addon Repository returned no add-ons, listing may have failed
11:51:39 T:1910330720 ERROR: Previous line repeats 1 times.
11:51:39 T:1910330720 NOTICE: Thread FileCache start, auto delete: false
11:51:39 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:40 T:1856826224 ERROR: Previous line repeats 1 times.
11:51:40 T:1856826224 NOTICE: Thread FileCache start, auto delete: false
11:51:40 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:40 T:1856822728 NOTICE: Thread FileCache start, auto delete: false
11:51:41 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:41 T:1856979440 NOTICE: Thread FileCache start, auto delete: false
11:51:41 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:42 T:1909631504 ERROR: Previous line repeats 1 times.
11:51:42 T:1909631504 NOTICE: Thread FileCache start, auto delete: false
11:51:42 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:42 T:1935675240 NOTICE: Thread FileCache start, auto delete: false
11:51:43 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:43 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:43 T:1856708320 NOTICE: Thread FileCache start, auto delete: false
11:51:43 T:1837081088 NOTICE: Previous line repeats 2 times.
11:51:44 T:1912072944 NOTICE: Thread FileCache start, auto delete: false
11:51:44 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:44 T:1908510456 NOTICE: Thread FileCache start, auto delete: false
11:51:44 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:45 T:1912010720 NOTICE: Thread FileCache start, auto delete: false
11:51:45 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:45 T:1854225832 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
11:51:45 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:45 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:45 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://raw.github.com/al101/repository.SportsDevil/master/addons.xml.md5>
11:51:45 T:1841885136 NOTICE: Thread LanguageInvoker start, auto delete: false
11:51:45 T:1841885136 NOTICE: -->Python Interpreter Initialized<--
11:51:45 T:1908444448 NOTICE: Thread BackgroundLoader start, auto delete: false
11:51:45 T:1913196056 NOTICE: Thread JobWorker start, auto delete: true
11:51:46 T:1854225832 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404
11:51:46 T:1854225832 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
11:51:46 T:1854225832 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://raw.github.com/al101/repository.SportsDevil/master/addons.xml>
11:51:46 T:1854225832 ERROR: Repository SportsDevil repository returned no add-ons, listing may have failed
11:51:46 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:46 T:1909674160 NOTICE: Thread FileCache start, auto delete: false
11:51:47 T:1910471296 ERROR: Previous line repeats 1 times.
11:51:47 T:1910471296 NOTICE: Thread LanguageInvoker start, auto delete: false
11:51:47 T:1910471296 NOTICE: -->Python Interpreter Initialized<--
11:51:47 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:48 T:1910471296 NOTICE: CommonFunctions-2.5.1
11:51:48 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:48 T:1910471296 NOTICE: metahandler: Initializing MetaHandlers version: 2.7.0
11:51:49 T:1910471296 NOTICE: metahandler: Loading sqlite3 as DB engine version: 3.8.6
11:51:49 T:1910471296 NOTICE: metahandler: Looking up TMDB config cache values
11:51:49 T:1910471296 NOTICE: metahandler: Cache still valid, setting values
11:51:49 T:1910471296 NOTICE: metahandler: No SQLite rows requiring update
11:51:49 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:49 T:1854211960 NOTICE: Thread LanguageInvoker start, auto delete: false
11:51:49 T:1854211960 NOTICE: -->Python Interpreter Initialized<--
11:51:49 T:1855352152 NOTICE: Thread BackgroundLoader start, auto delete: false
11:51:50 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:51:50 T:1909563920 NOTICE: Thread BackgroundLoader start, auto delete: false
11:51:50 T:1837081088 NOTICE: Previous line repeats 1 times.
11:51:54 T:1843333912 ERROR: Previous line repeats 7 times.
11:51:54 T:1843333912 NOTICE: Thread LanguageInvoker start, auto delete: false
11:51:54 T:1843333912 NOTICE: -->Python Interpreter Initialized<--
11:52:07 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:52:08 T:1944785512 ERROR: Previous line repeats 1 times.
11:52:08 T:1944785512 NOTICE: Thread BackgroundLoader start, auto delete: false
11:52:08 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:52:13 T:1935722888 ERROR: Previous line repeats 9 times.
11:52:13 T:1935722888 NOTICE: Thread LanguageInvoker start, auto delete: false
11:52:13 T:1935722888 NOTICE: -->Python Interpreter Initialized<--
11:52:18 T:1781277528 NOTICE: DVDPlayer: Opening: https://r2---sn-ni5f-t8ge.googlevideo.co...mv=m&pl=23
11:52:18 T:1781277528 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
11:52:18 T:1935910528 NOTICE: Thread DVDPlayer start, auto delete: false
11:52:18 T:1935910528 NOTICE: Creating InputStream
11:52:18 T:1839529200 NOTICE: Thread FileCache start, auto delete: false
11:52:18 T:1935910528 NOTICE: Creating Demuxer
11:52:19 T:1935910528 NOTICE: Opening stream: 0 source: 256
11:52:19 T:1935910528 NOTICE: Creating video codec with codec id: 28
11:52:19 T:1935910528 NOTICE: Creating video thread
11:52:19 T:1944785512 NOTICE: Thread DVDPlayerVideo start, auto delete: false
11:52:19 T:1935910528 NOTICE: Opening stream: 1 source: 256
11:52:19 T:1944785512 NOTICE: running thread: video_thread
11:52:19 T:1935910528 NOTICE: Finding audio codec for: 86018
11:52:19 T:1935910528 NOTICE: Creating audio thread
11:52:19 T:1910010816 NOTICE: Thread DVDPlayerAudio start, auto delete: false
11:52:19 T:1910010816 NOTICE: running thread: CDVDPlayerAudio:rocess()
11:52:19 T:1910010816 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 44100, no pass-through)
11:52:19 T:1932688808 NOTICE: Thread CAMLCodec start, auto delete: false
11:52:19 T:1845898968 NOTICE: 1Channel: Service: Playback started
11:52:19 T:1944785512 NOTICE: fps: 29.970030, pwidth: 1280, pheight: 640, dwidth: 1280, dheight: 640
11:52:19 T:1944785512 NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (16)
11:52:19 T:1781277528 NOTICE: Using GL_TEXTURE_2D
11:52:19 T:1781277528 NOTICE: GL: Using BYPASS render method
11:52:19 T:1781277528 NOTICE: GL: NPOT texture support detected
11:52:32 T:1944785512 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
11:52:56 T:1910010816 WARNING: Previous line repeats 9 times.
11:52:56 T:1910010816 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
11:52:56 T:1944785512 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
11:53:07 T:1781277528 WARNING: Previous line repeats 6 times.
11:53:07 T:1781277528 NOTICE: CDVDPlayer::CloseFile()
11:53:07 T:1781277528 NOTICE: DVDPlayer: waiting for threads to exit
11:53:07 T:1935910528 NOTICE: CDVDPlayer::OnExit()
11:53:07 T:1935910528 NOTICE: Closing stream player 1
11:53:07 T:1935910528 NOTICE: Waiting for audio thread to exit
11:53:07 T:1910010816 NOTICE: thread end: CDVDPlayerAudio::OnExit()
11:53:07 T:1935910528 NOTICE: Closing audio device
11:53:07 T:1935910528 NOTICE: Deleting audio codec
11:53:07 T:1935910528 NOTICE: Closing stream player 2
11:53:07 T:1935910528 NOTICE: waiting for video thread to exit
11:53:07 T:1944785512 NOTICE: thread end: video_thread
11:53:07 T:1935910528 NOTICE: deleting video codec
11:53:07 T:1781277528 NOTICE: DVDPlayer: finished waiting
11:53:07 T:1845898968 NOTICE: 1Channel: Service: Playback Stopped
11:53:07 T:1845898968 NOTICE: 1Channel: Service: Resetting...
11:53:08 T:1909343928 NOTICE: Thread BackgroundLoader start, auto delete: false
11:53:08 T:1781277528 NOTICE: CDVDPlayer::CloseFile()
11:53:08 T:1781277528 NOTICE: DVDPlayer: waiting for threads to exit
11:53:08 T:1781277528 NOTICE: DVDPlayer: finished waiting
11:53:08 T:1944451736 NOTICE: Thread JobWorker start, auto delete: true
11:53:13 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:14 T:1941680240 NOTICE: Thread LanguageInvoker start, auto delete: false
11:53:14 T:1941680240 NOTICE: -->Python Interpreter Initialized<--
11:53:14 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:14 T:1941680240 NOTICE: CommonFunctions-2.5.1
11:53:14 T:1941680240 NOTICE: metahandler: Initializing MetaHandlers version: 2.7.0
11:53:15 T:1941680240 NOTICE: metahandler: Loading sqlite3 as DB engine version: 3.8.6
11:53:15 T:1941680240 NOTICE: metahandler: Looking up TMDB config cache values
11:53:15 T:1941680240 NOTICE: metahandler: Cache still valid, setting values
11:53:15 T:1941680240 NOTICE: metahandler: No SQLite rows requiring update
11:53:15 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:15 T:1916888048 NOTICE: Thread BackgroundLoader start, auto delete: false
11:53:16 T:1837383520 NOTICE: Previous line repeats 1 times.
11:53:16 T:1837383520 NOTICE: Thread JobWorker start, auto delete: true
11:53:16 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:17 T:1916888048 ERROR: Previous line repeats 1 times.
11:53:17 T:1916888048 NOTICE: Thread LanguageInvoker start, auto delete: false
11:53:17 T:1916888048 NOTICE: -->Python Interpreter Initialized<--
11:53:17 T:1841541856 NOTICE: Thread BackgroundLoader start, auto delete: false
11:53:17 T:1941393952 NOTICE: Thread JobWorker start, auto delete: true
11:53:17 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:19 T:1912085280 ERROR: Previous line repeats 3 times.
11:53:19 T:1912085280 NOTICE: Thread LanguageInvoker start, auto delete: false
11:53:19 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:19 T:1912085280 NOTICE: -->Python Interpreter Initialized<--
11:53:19 T:1839710288 NOTICE: Thread BackgroundLoader start, auto delete: false
11:53:20 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:23 T:1911094448 ERROR: Previous line repeats 7 times.
11:53:23 T:1911094448 NOTICE: Thread LanguageInvoker start, auto delete: false
11:53:23 T:1911094448 NOTICE: -->Python Interpreter Initialized<--
11:53:24 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:24 T:1911094448 NOTICE: CommonFunctions-2.5.1
11:53:33 T:1856870208 ERROR: Previous line repeats 18 times.
11:53:33 T:1856870208 NOTICE: Thread BackgroundLoader start, auto delete: false
11:53:34 T:1856870208 NOTICE: Thread JobWorker start, auto delete: true
11:53:34 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:46 T:1931062112 ERROR: Previous line repeats 23 times.
11:53:46 T:1931062112 NOTICE: Thread LanguageInvoker start, auto delete: false
11:53:46 T:1931062112 NOTICE: -->Python Interpreter Initialized<--
11:53:46 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:46 T:1931062112 NOTICE: CommonFunctions-2.5.1
11:53:47 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:50 T:1935883368 ERROR: Previous line repeats 7 times.
11:53:50 T:1935883368 NOTICE: Thread BackgroundLoader start, auto delete: false
11:53:51 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:55 T:1856834144 ERROR: Previous line repeats 9 times.
11:53:55 T:1856834144 NOTICE: Thread LanguageInvoker start, auto delete: false
11:53:55 T:1856834144 NOTICE: -->Python Interpreter Initialized<--
11:53:56 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:53:56 T:1856834144 NOTICE: CommonFunctions-2.5.1
11:54:00 T:1939976600 ERROR: Previous line repeats 6 times.
11:54:00 T:1939976600 NOTICE: Thread BackgroundLoader start, auto delete: false
11:54:00 T:1837081088 NOTICE: Previous line repeats 1 times.
11:54:00 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:54:05 T:1904800072 ERROR: Previous line repeats 10 times.
11:54:05 T:1904800072 NOTICE: Thread LanguageInvoker start, auto delete: false
11:54:05 T:1904800072 NOTICE: -->Python Interpreter Initialized<--
11:54:05 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:54:05 T:1904800072 NOTICE: CommonFunctions-2.5.1
11:54:06 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:54:09 T:1931168832 ERROR: Previous line repeats 5 times.
11:54:09 T:1931168832 NOTICE: Thread BackgroundLoader start, auto delete: false
11:54:09 T:1837081088 NOTICE: Previous line repeats 1 times.
11:54:09 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:54:14 T:1918591840 ERROR: Previous line repeats 10 times.
11:54:14 T:1918591840 NOTICE: Thread LanguageInvoker start, auto delete: false
11:54:14 T:1918591840 NOTICE: -->Python Interpreter Initialized<--
11:54:15 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:54:15 T:1918591840 NOTICE: CommonFunctions-2.5.1
11:54:19 T:1914274920 ERROR: Previous line repeats 7 times.
11:54:19 T:1914274920 NOTICE: Thread BackgroundLoader start, auto delete: false
11:54:20 T:1837081088 NOTICE: Previous line repeats 1 times.
11:54:20 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:54:25 T:1841921816 ERROR: Previous line repeats 11 times.
11:54:25 T:1841921816 NOTICE: Thread LanguageInvoker start, auto delete: false
11:54:25 T:1841921816 NOTICE: -->Python Interpreter Initialized<--
11:54:26 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:54:26 T:1841921816 NOTICE: CommonFunctions-2.5.1
11:54:29 T:1910023632 ERROR: Previous line repeats 5 times.
11:54:29 T:1910023632 NOTICE: Thread BackgroundLoader start, auto delete: false
11:54:29 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:54:58 T:1944391056 ERROR: Previous line repeats 56 times.
11:54:58 T:1944391056 NOTICE: Thread LanguageInvoker start, auto delete: false
11:54:58 T:1944391056 NOTICE: -->Python Interpreter Initialized<--
11:54:58 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:54:58 T:1944391056 NOTICE: CommonFunctions-2.5.1
11:54:59 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:01 T:1841921816 ERROR: Previous line repeats 5 times.
11:55:01 T:1841921816 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:02 T:1837081088 NOTICE: Previous line repeats 1 times.
11:55:02 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:05 T:1944967216 ERROR: Previous line repeats 7 times.
11:55:05 T:1944967216 NOTICE: Thread LanguageInvoker start, auto delete: false
11:55:05 T:1944967216 NOTICE: -->Python Interpreter Initialized<--
11:55:06 T:1944967216 NOTICE: CommonFunctions-2.5.1
11:55:06 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:09 T:1914434848 ERROR: Previous line repeats 5 times.
11:55:09 T:1914434848 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:09 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:14 T:1944813680 ERROR: Previous line repeats 10 times.
11:55:14 T:1944813680 NOTICE: Thread LanguageInvoker start, auto delete: false
11:55:14 T:1944813680 NOTICE: -->Python Interpreter Initialized<--
11:55:14 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:15 T:1944813680 NOTICE: CommonFunctions-2.5.1
11:55:15 T:1904800072 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:15 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:18 T:1936499376 ERROR: Previous line repeats 4 times.
11:55:18 T:1936499376 NOTICE: Thread LanguageInvoker start, auto delete: false
11:55:18 T:1936499376 NOTICE: -->Python Interpreter Initialized<--
11:55:18 T:1936499376 NOTICE: CommonFunctions-2.5.1
11:55:18 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:18 T:1936499376 NOTICE: metahandler: Initializing MetaHandlers version: 2.7.0
11:55:19 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:19 T:1936499376 NOTICE: metahandler: Loading sqlite3 as DB engine version: 3.8.6
11:55:19 T:1936499376 NOTICE: metahandler: Looking up TMDB config cache values
11:55:19 T:1936499376 NOTICE: metahandler: Cache still valid, setting values
11:55:19 T:1936499376 NOTICE: metahandler: No SQLite rows requiring update
11:55:19 T:1944710552 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:19 T:1837081088 NOTICE: Previous line repeats 1 times.
11:55:22 T:1916154568 ERROR: Previous line repeats 4 times.
11:55:22 T:1916154568 NOTICE: Thread LanguageInvoker start, auto delete: false
11:55:22 T:1916154568 NOTICE: -->Python Interpreter Initialized<--
11:55:22 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:31 T:1935639824 ERROR: Previous line repeats 1 times.
11:55:31 T:1935639824 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:31 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:37 T:1854667632 ERROR: Previous line repeats 11 times.
11:55:37 T:1854667632 NOTICE: Thread LanguageInvoker start, auto delete: false
11:55:37 T:1854667632 NOTICE: -->Python Interpreter Initialized<--
11:55:37 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:38 T:1854667632 NOTICE: CommonFunctions-2.5.1
11:55:38 T:1854667632 NOTICE: metahandler: Initializing MetaHandlers version: 2.7.0
11:55:38 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:38 T:1854667632 NOTICE: metahandler: Loading sqlite3 as DB engine version: 3.8.6
11:55:38 T:1854667632 NOTICE: metahandler: Looking up TMDB config cache values
11:55:38 T:1854667632 NOTICE: metahandler: Cache still valid, setting values
11:55:38 T:1854667632 NOTICE: metahandler: No SQLite rows requiring update
11:55:38 T:1944727512 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:38 T:1837081088 NOTICE: Previous line repeats 1 times.
11:55:39 T:1938237840 ERROR: Previous line repeats 1 times.
11:55:39 T:1938237840 NOTICE: Thread LanguageInvoker start, auto delete: false
11:55:39 T:1938237840 NOTICE: -->Python Interpreter Initialized<--
11:55:39 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:40 T:1938237840 NOTICE: CommonFunctions-2.5.1
11:55:40 T:1936499376 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:40 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:42 T:1936499376 ERROR: Previous line repeats 4 times.
11:55:42 T:1936499376 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:43 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:45 T:1910023632 ERROR: Previous line repeats 3 times.
11:55:45 T:1910023632 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:45 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:46 T:1936557704 ERROR: Previous line repeats 2 times.
11:55:46 T:1936557704 NOTICE: Thread LanguageInvoker start, auto delete: false
11:55:46 T:1936557704 NOTICE: -->Python Interpreter Initialized<--
11:55:46 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:46 T:1936557704 NOTICE: CommonFunctions-2.5.1
11:55:46 T:1838239656 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:47 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:51 T:1841921816 ERROR: Previous line repeats 8 times.
11:55:51 T:1841921816 NOTICE: Thread LanguageInvoker start, auto delete: false
11:55:51 T:1841921816 NOTICE: -->Python Interpreter Initialized<--
11:55:51 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:51 T:1841921816 NOTICE: CommonFunctions-2.5.1
11:55:52 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:54 T:1903321560 ERROR: Previous line repeats 5 times.
11:55:54 T:1903321560 NOTICE: Thread BackgroundLoader start, auto delete: false
11:55:55 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:59 T:1839534592 ERROR: Previous line repeats 8 times.
11:55:59 T:1839534592 NOTICE: Thread LanguageInvoker start, auto delete: false
11:55:59 T:1839534592 NOTICE: -->Python Interpreter Initialized<--
11:55:59 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:55:59 T:1839534592 NOTICE: CommonFunctions-2.5.1
11:56:00 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:56:02 T:1905960480 ERROR: Previous line repeats 5 times.
11:56:02 T:1905960480 NOTICE: Thread BackgroundLoader start, auto delete: false
11:56:03 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:56:07 T:1855352152 ERROR: Previous line repeats 7 times.
11:56:07 T:1855352152 NOTICE: Thread LanguageInvoker start, auto delete: false
11:56:07 T:1855352152 NOTICE: -->Python Interpreter Initialized<--
11:56:07 T:1837081088 ERROR: EXCEPTION: Window id does not exist
11:56:07 T:1855352152 NOTICE: CommonFunctions-2.5.1
11:56:10 T:1909810320 ERROR: Previous line repeats 5 times.
11:56:10 T:1909810320 NOTICE: Thread BackgroundLoader start, auto delete: false
