Full Version: play ongoing records
Hi @ all,
should it be possible to have full access and "timeshift-functionality"on ongoing recordings from kodi on enigma-receiver?
I tested it in my configuration.
I tested with 720p- channel (Das Erste HD). First I had the impression, it works, because the video played and as the player reached in the timecode showed end of file, the player did go on and the timecode of the video file increased second by second (you see it ny actovated OSD on the right site) - you know what i mean?
That was, what i expected in best case. BUT: after some seconds the playback stopped and i had to start the playback again.
My question is: should this feature work without stopping playback ?
On DVBViewer PVR there is this feature implemented since some weeks and i can watch ongoing recordings without restarting. Should this work on enigma pvr as well?
One difference is, that my enigma receiver has a 400MHZ CPU and 100 mbit ethernet only. The PC with dvbviewer is much faster and has gigabit-LAN. But channel-streaming on enigma works normally without streaming-problems.
SaEt9000
