2015-07-18, 14:55
Just a heads up
Sintech SATA HDD to M.2(NGFF) B key Socket adapter card +USB power SATA cable (£12.79/$19.99)
http://www.ebay.co.uk/itm/Sintech-SATA-H...33935ee9ae
Name: SATA SSD/HDD to M.2(NGFF) Socket adapter converter card+USB power SATA cable
Features
T5111 is SATA adapter from M.2 Socket 2. This module allows you connect any SATA device to M.2 slot through a standard SATA port.
M2S supports M.2 socket 2 with TYPE 2242-D2-B-M of SATA SSD. SATA interface supports standard SATA 7pin data signals. ST5111 is the best solution to evaluate M.2 SATA SSD socket.
Specifications
Standard SATA interface adapter from M.2 Socket 2 slot for SATA SSD
Compliant with PCIe M.2 Specification Rev 0.7
Body Size: TYPE 2242-D2-B-M, can be as type 22x42, type 22x60,type 22x80 M.2 SSD.
Module Key : B+M (Both Key B and Key M)
Interface : Standard SATA 7pin Connector
Compliant with Serial ATA Revision 3.1
length of USB power cable: 50cms
Notice: USB power supply only can support 1.8 or 2.5" SATA SSD or HDD,it can't support 3.5" SATA HDD.
Package
1x SATA SSD to M.2 adapter card
1x USB power SATA cable 50cms
Features
Specifications
Package
