Hi
I just got fed up with TVH and installed VDR with VNSI:5. From my first test it is working well.
VDR is running on Debian wheezy (Openmediavault). The SSD has a small system partition and a bigger one which I wanted to use for timeshift data.
Since I did not stumble upon an option to store the TS data in VDR I wonder where VDR / VNSI is storing the timeshift data - since TS setting is under "client specific" I assume it is stored on the clients HDD, correct?
If it is stored on the VDR server where is folder and can it be changed?
thx
LOL - Found it :-) , it is in the recording folder "Timeshift-*.vnsi"
FernetMenta
Can this be moved to a different folder/partition?
yes, check out TimeshiftBufferDir in setup.conf. You can change this via vdr ui.
(2015-07-19, 13:04)FernetMenta Wrote: [ -> ]yes, check out TimeshiftBufferDir in setup.conf. You can change this via vdr ui.
Hi
Thx, but sadly that entry is missing.
Will a simple "TimeshiftBufferDir = /media/mypoartition/folder/" suffice?
My setup.conf:
AlwaysSortFoldersFirst = 1
AntiAlias = 1
AudioLanguages = deu eng
ChannelEntryTimeout = 1000
ChannelInfoPos = 0
ChannelInfoTime = 5
ChannelsWrap = 0
ColorKey0 = 0
ColorKey1 = 1
ColorKey2 = 2
ColorKey3 = 3
CurrentChannel = -1
CurrentDolby = 0
CurrentVolume = 255
DefaultLifetime = 99
DefaultPriority = 50
DelTimeshiftRec = 0
DeviceBondings =
DiSEqC = 1
DisplaySubtitles = 0
EmergencyExit = 1
EPGBugfixLevel = 3
EPGLanguages = deu
EPGLinger = 0
EPGScanTimeout = 5
FoldersInTimerMenu = 1
FontFix = Courier:Bold
FontFixSize = 17
FontFixSizeP = 0.030000
FontOsd = Sans Serif:Bold
FontOsdSize = 18
FontOsdSizeP = 0.031000
FontSml = Sans Serif
FontSmlSize = 16
FontSmlSizeP = 0.028000
InitialChannel =
InitialVolume = -1
InstantRecordTime = 180
LnbFrequHi = 10600
LnbFrequLo = 9750
LnbSLOF = 11700
MarginStart = 2
MarginStop = 10
MarkInstantRecord = 1
MaxVideoFileSize = 32000
MenuKeyCloses = 0
MenuScrollPage = 1
MenuKeyCloses = 0
MenuScrollPage = 1
MenuScrollWrap = 0
MinEventTimeout = 30
MinUserInactivity = 0
MultiSpeedMode = 0
NameInstantRecord = TITLE EPISODE
NextWakeupTime = 0
NumberKeysForChars = 1
OSDAspect = 1.422222
OSDHeight = 484
OSDHeightP = 0.840000
OSDLanguage =
OSDLeft = 58
OSDLeftP = 0.080000
OSDMessageTime = 1
OSDSkin = lcars
OSDTheme = default
OSDTop = 46
OSDTopP = 0.080000
OSDWidth = 624
OSDWidthP = 0.870000
PauseKeyHandling = 2
PauseLifetime = 1
PauseOnMarkSet = 0
PausePriority = 10
PrimaryDVB = 5
ProgressDisplayTime = 0
RcRepeatDelay = 300
RcRepeatDelta = 100
RecordingDirs = 1
ResumeID = 0
SetSystemTime = 0
ShowChannelNamesWithSource = 0
ShowInfoOnChSwitch = 1
ShowRemainingTime = 0
ShowReplayMode = 0
SplitEditedFiles = 0
StandardCompliance = 0
SubtitleBgTransparency = 0
SubtitleFgTransparency = 0
SubtitleLanguages =
SubtitleOffset = 0
SupportTeletext = 1
SVDRPTimeout = 300
TimeoutRequChInfo = 1
TimeSource =
TimeSource =
TimeTransponder = 0
UpdateChannels = 4
UseDolbyDigital = 1
UseSmallFont = 1
UseSubtitle = 0
UseVps = 0
VideoDisplayFormat = 1
VideoFormat = 0
VpsMargin = 120
ZapTimeout = 3
vnsiserver.Timeshift = 2
vnsiserver.TimeshiftBufferFileSize = 20
it will be created when you open the plugin's setup dialog for the first time. go to system, tv, client specific and navigate vdr ui: setup, plugins, vnsiserver
(2015-07-19, 14:53)FernetMenta Wrote: [ -> ]it will be created when you open the plugin's setup dialog for the first time. go to system, tv, client specific and navigate vdr ui: setup, plugins, vnsiserver
Ahh ok.
I just don't have a GUI/OSD since it is running headless on my Openmediavault server - so I have to make that entry manually in y setup.conf.
you run Kodi headless? how do you watch tv then?
(2015-07-19, 18:01)FernetMenta Wrote: [ -> ]you run Kodi headless? how do you watch tv then?
Kodi is on a different machine
Headless server: Openmediavault with DD 4x CineS2 6.5 and VDR and Emby media server
Clients: 1 HTPC and a couple of Notebooks with Kodi or Emby Webinterface
nevertheless the parameters do look like this in setup.conf:
vnsiserver.AvoidEPGScan = 0
vnsiserver.PlayRecording = 0
vnsiserver.PmtTimeout = 5
vnsiserver.Timeshift = 0
vnsiserver.TimeshiftBufferDir =
vnsiserver.TimeshiftBufferFileSize = 6
vnsiserver.TimeshiftBufferSize = 5
