Full Version: Timeshift unstable - TVH 4.0.5 and Kodi 15.0rc2 (OE)
Hi, After many failed attemps I'm trying to use timeshifting again. Unfortunately it's not stable enough.
Debug log: http://sprunge.us/OIcE
At 15:54:33 the screen freezes for about 20 seconds and continues again at 15:54:51.
This happened after skipping back and forth in the buffer (-30 sec and +30 sec).
It's more or less constantly happening,so normal live tv is fine until I skip -30 sec and after some time the screen freezes.
Is there anything in the log that points to a config issue or something else? I'd really like to get this working, it's the only issue left with my htpc.
You'll have to file a bug report at tvheadend.org, I'm almost 100% sure that's where the bug is.
That would make sense because it seems to happen in any Kodi version I've tried so far.
Any clue as what could be causing this in tvh?
I think it's the relatively recent addition of "timeshift to RAM".
Thanks. I still mount a folder with tmpfs so not using the native ram solution in tvh. But I've been reading the bug tracker and I see the issue I have is already reported so I'll wait and see for now.
Any update on this? It seems to be similar to the issue I am facing with timeshifting.
Is https://tvheadend.org/issues/3033 your bug report?
Yes. But I don't think it's being looked at yet.
