2015-07-22, 07:11
I developed a program addon to display list of books i have which requires logging in so I made a custom window to take both username and password. But after entering username and password when i click on log in button kodi crashes and gives segmentation fault. Here's the crash report.
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Wed Jul 22 10:03:35 IST 2015
Kodi Options:
Arch: x86_64
Kernel: Linux 3.13.0-57-generic #95-Ubuntu SMP Fri Jun 19 09:28:15 UTC 2015
Release: Ubuntu 14.04.2 LTS, Trusty Tahr
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
10:02:44 T:140131360040896 NOTICE: special://profile/ is mapped to: special://masterprofile/
10:02:44 T:140131360040896 NOTICE: -----------------------------------------------------------------------
10:02:44 T:140131360040896 NOTICE: Starting Kodi (14.2 Git:7cc53a9). Platform: Linux x86 64-bit
10:02:44 T:140131360040896 NOTICE: Using Release Kodi x64 build
10:02:44 T:140131360040896 NOTICE: Kodi compiled Mar 27 2015 by GCC 4.8.2 for Linux x86 64-bit version 3.13.11 (199947)
10:02:44 T:140131360040896 NOTICE: Running on Ubuntu 14.04.2 LTS, kernel: Linux x86 64-bit version 3.13.0-57-generic
10:02:44 T:140131360040896 NOTICE: FFmpeg statically linked, version: 2.4.6-xbmc-2.4.6-Helix
10:02:44 T:140131360040896 NOTICE: Host CPU: Intel® Core i3 CPU M 350 @ 2.27GHz, 4 cores available
10:02:44 T:140131360040896 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
10:02:44 T:140131360040896 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
10:02:44 T:140131360040896 NOTICE: special://masterprofile/ is mapped to: /home/jaysheel/.kodi/userdata
10:02:44 T:140131360040896 NOTICE: special://home/ is mapped to: /home/jaysheel/.kodi
10:02:44 T:140131360040896 NOTICE: special://temp/ is mapped to: /home/jaysheel/.kodi/temp
10:02:44 T:140131360040896 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
10:02:44 T:140131360040896 NOTICE: Local hostname: orion
10:02:44 T:140131360040896 NOTICE: Log File is located: /home/jaysheel/.kodi/temp/kodi.log
10:02:45 T:140131360040896 NOTICE: load settings...
10:02:45 T:140131360040896 NOTICE: Found 1 Lists of Devices
10:02:45 T:140131360040896 NOTICE: Enumerated PULSE devices:
10:02:45 T:140131360040896 NOTICE: Device 1
10:02:45 T:140131360040896 NOTICE: m_deviceName : Default
10:02:45 T:140131360040896 NOTICE: m_displayName : Default
10:02:45 T:140131360040896 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
10:02:45 T:140131360040896 NOTICE: m_deviceType : AE_DEVTYPE_PCM
10:02:45 T:140131360040896 NOTICE: m_channels : FL,FR
10:02:45 T:140131360040896 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
10:02:45 T:140131360040896 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
10:02:45 T:140131360040896 NOTICE: Device 2
10:02:45 T:140131360040896 NOTICE: m_deviceName : alsa_output.pci-0000_00_1b.0.analog-stereo
10:02:45 T:140131360040896 NOTICE: m_displayName : Built-in Audio Analog Stereo
10:02:45 T:140131360040896 NOTICE: m_displayNameExtra: Speakers (PULSEAUDIO)
10:02:45 T:140131360040896 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
10:02:45 T:140131360040896 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
10:02:45 T:140131360040896 NOTICE: Default DVD Player: dvdplayer
10:02:45 T:140131360040896 NOTICE: Default Video Player: dvdplayer
10:02:45 T:140131360040896 NOTICE: Default Audio Player: paplayer
10:02:45 T:140131360040896 NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:02:45 T:140131360040896 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:02:45 T:140131360040896 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:02:45 T:140131360040896 NOTICE: Loaded playercorefactory configuration
10:02:45 T:140131360040896 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:02:45 T:140131360040896 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:02:45 T:140130884937472 NOTICE: Thread ActiveAE start, auto delete: false
10:02:45 T:140130944833280 NOTICE: Thread AESink start, auto delete: false
10:02:45 T:140130944833280 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
10:02:45 T:140131360040896 NOTICE: Running database version Addons16
10:02:46 T:140131360040896 NOTICE: ADDONS: Using repository repository.xbmc.org
10:02:46 T:140130918831872 NOTICE: Thread PeripBusCEC start, auto delete: false
10:02:46 T:140130910439168 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
10:02:46 T:140131360040896 NOTICE: Setup SDL
10:02:46 T:140131360040896 NOTICE: Checking resolution 15
10:02:46 T:140131360040896 NOTICE: Using visual 0x20
10:02:46 T:140131360040896 NOTICE: GL_VENDOR = Intel Open Source Technology Center
10:02:46 T:140131360040896 NOTICE: GL_RENDERER = Mesa DRI Intel® Ironlake Mobile
10:02:46 T:140131360040896 NOTICE: GL_VERSION = 2.1 Mesa 10.1.3
10:02:46 T:140131360040896 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
10:02:46 T:140131360040896 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_debug_output GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_texture_storage GL_AMD_shader_trinary_minmax GL_ARB_clear_buffer_object GL_ARB_invalidate_subdata GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge
10:02:47 T:140131360040896 NOTICE: Running database version Addons16
10:02:47 T:140131360040896 NOTICE: Running database version ViewModes6
10:02:47 T:140131360040896 NOTICE: Running database version Textures13
10:02:47 T:140131360040896 NOTICE: Running database version MyMusic48
10:02:47 T:140131360040896 NOTICE: Running database version MyVideos90
10:02:47 T:140131360040896 NOTICE: Running database version TV26
10:02:47 T:140131360040896 NOTICE: Running database version Epg8
10:02:47 T:140131360040896 NOTICE: start dvd mediatype detection
10:02:47 T:140131359577856 NOTICE: Thread DetectDVDMedia start, auto delete: false
10:02:48 T:140131360040896 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
10:02:48 T:140131360040896 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
10:02:48 T:140131360040896 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
10:02:48 T:140131360040896 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
10:02:48 T:140130553673472 NOTICE: Thread LanguageInvoker start, auto delete: false
10:02:48 T:140131360040896 NOTICE: initialize done
10:02:48 T:140130545280768 NOTICE: Thread LanguageInvoker start, auto delete: false
10:02:48 T:140131360040896 NOTICE: Running the application...
10:02:49 T:140130553673472 NOTICE: -->Python Interpreter Initialized<--
10:02:50 T:140130545280768 NOTICE: Previous line repeats 1 times.
10:02:50 T:140130545280768 NOTICE: StorageServer Module loaded RUN
10:02:50 T:140130545280768 NOTICE: StorageClient-2.5.4 Starting server
10:02:51 T:140130515814144 NOTICE: Thread JobWorker start, auto delete: true
10:02:51 T:140131360040896 NOTICE: starting zeroconf publishing
10:02:51 T:140131360040896 NOTICE: ES: Starting event server
10:02:51 T:140130499028736 NOTICE: Thread JobWorker start, auto delete: true
10:02:51 T:140130010523392 NOTICE: Thread TCPServer start, auto delete: false
10:02:51 T:140130002130688 NOTICE: Thread JobWorker start, auto delete: true
10:02:51 T:140130018916096 NOTICE: Thread EventServer start, auto delete: false
10:02:51 T:140130018916096 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
10:02:51 T:140130018916096 NOTICE: UDP: Listening on port 9777
10:02:51 T:140131358549760 NOTICE: Thread RSSReader start, auto delete: false
10:02:51 T:140129967519488 NOTICE: Thread FileCache start, auto delete: false
10:02:55 T:140129993737984 NOTICE: Previous line repeats 2 times.
10:02:55 T:140129993737984 NOTICE: Thread BackgroundLoader start, auto delete: false
10:02:57 T:140130553673472 NOTICE: Thread LanguageInvoker start, auto delete: false
10:02:57 T:140130553673472 NOTICE: -->Python Interpreter Initialized<--
10:03:01 T:140130553673472 NOTICE: sys.argv
10:03:01 T:140130553673472 NOTICE: params:
10:03:01 T:140130553673472 NOTICE: []
10:03:02 T:140129967519488 NOTICE: Thread FileCache start, auto delete: false
10:03:09 T:140130553673472 NOTICE: 1
10:03:09 T:140130553673472 NOTICE: -------------------------- Not logged in
10:03:14 T:140129967519488 NOTICE: Thread BackgroundLoader start, auto delete: false
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
Kodi Options:
Arch: x86_64
