V1.0.2 in my git:
https://github.com/learningit/plugin.vid...ork.canada
Has subtitles and ability to set views - see the addon settings.
Still a couple of quirks of non playing menu items to work out.
If you have installed my test repo:
https://github.com/learningit/repository...odi_addons
You should get an "auto-update" or "update available" message, depending on your "auto-update" setting. You may need to do a "Check for updates" to see the new version.
Please let me know if this works so that I can get the kodi.org repo updated.
Thank you very much for this.
Do you know if there is a simple way to save some of these like Bobby Flay's bbq for later offline view? I have read that I may have to install som PVR, but I am only intressted in som of these for offline viewing.and do not have a TV-tuner either.
Works great in Germany, thanks.
Works great. Thank you very much, as always.
Got it from your repo and it works as advertised.Thank you
(2015-07-22, 11:40)satelit20 Wrote: [ -> ]Thank you very much for this.
No.
Awesome plugin and works well. For some reason i cant see any HD feeds? - Are most of them in SD?
(2015-07-25, 22:34)cablegoon Wrote: [ -> ]Awesome plugin and works well. For some reason i cant see any HD feeds? - Are most of them in SD?
I think 540 is the max the addon finds, most are 480.
looks good eitherways - thanks for this and all your other apps
Works in New Zealand, thanks.
V1.0.3 updated in the kodi.org repo
this was working yesterday, but as of today (september 2nd) it stopped working. some files give an error of "one or more items failed to play" after the opening stream popup. while other streams show the opening stream pop up but then just goes back to the list view.
and here is the log. i got the log right after i got an error of each kind (unable to play stream and just going back to the list of episodes)
http://pastebin.com/4YFcqu06
edit: i tried the plugin on my computer and its working fine. so the log above is from my firetv stick, which was working yesterday but not today. can someone help me figure out whats going on
(2015-09-02, 06:12)nmirza Wrote: [ -> ]this was working yesterday, but as of today (september 2nd) it stopped working. some files give an error of "one or more items failed to play" after the opening stream popup. while other streams show the opening stream pop up but then just goes back to the list view.
You seem to be getting a curl 22 error which can be a number of things. If you are outside of Canada or the US, you may require a proxy. If you are using a proxy, make sure that it has https support which is required for this addon. I tested with 15.2 and had no issues at all playing the same episodes.
(2015-09-02, 13:28)learningit Wrote: [ -> ] (2015-09-02, 06:12)nmirza Wrote: [ -> ]this was working yesterday, but as of today (september 2nd) it stopped working. some files give an error of "one or more items failed to play" after the opening stream popup. while other streams show the opening stream pop up but then just goes back to the list view.
Ok I just updated my firetv stick to 15.2 as well and it's working again. That is very interesting and odd. Hopefully it keeps working. I am indeed outside North America. When I go on the website it doesn't play saying there's a region restriction but in kodi it works so I'm happy.
Another minor problem. There was a show listed in the plugin till yesterday - bake with Anna Olson. It is no longer available on any of my kodi installs in food network canada plugin. Not that it can't play but rather it's not in the list of shows.
I might have a hunch as to why that is. Today, September 6, a new season of the show started. So I'm thinking maybe the website code got updated to accommodate this.
The show is still available on the website btw just not in the plugin.
