When loading subtitles from Opensubtitles and stutters video when loading from Titlovi.com. Podnapisi.net seems fine.
No problem with Confluence default skin
could you please provide a
Debug Log and a crashlog (if kodi creates one)?
Kodi debug
http://pastebin.com/mGSzqQkH
Crashlog
oblem Event Name: APPCRASH
Application Name: Kodi.exe
Application Version: 15.0.0.0
Application Timestamp: 55ae9729
Fault Module Name: StackHash_14a8
Fault Module Version: 6.3.9600.17736
Fault Module Timestamp: 550f42c2
Exception Code: c0000374
Exception Offset: PCH_2E_FROM_ntdll+0x0003CA2C
OS Version: 6.3.9600.2.0.0.256.48
Locale ID: 1050
Additional Information 1: 14a8
Additional Information 2: 14a83dba80fb16afcc452b5471092e01
Additional Information 3: 232b
Additional Information 4: 232b384bee06ea2f9f136eba05400baf
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=280262
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
thx, i've been trying to reproduce it, but no luck.
could you test with a fresh profile?
simply rename C:\Users\Toni\AppData\Roaming\Kodi to C:\Users\Toni\AppData\Roaming\Kodi-old
and then start kodi.
now only install transparency, podnapisi and opensubtiltes, and check if it still crashes.
The problem is with serbian language in Kodi subtitle settings.
Once this language is added - BUM - Kodi crashes.
(2015-07-22, 22:51)versus Wrote: [ -> ]The problem is with serbian language in Kodi subtitle settings.
not on my end. i enabled the same languages as you have (serbian, croatian, english).
have you tried the fresh install?
ah got it, i managed to make it crash here as well.
edit:
looks like it's caused by by image of the serbian flag
19:48:11 T:9064 ERROR: Texture manager unable to load bundled file: countries/sr.gif
a fixed version of Transparency! should pop up within the next day or so.
Thanks man. Nice to see devs that react so promptly.
