(2015-12-16, 11:19)mozomo Wrote: [ -> ]Love this skin and use it everyday with Jarvis! No complaints so far
I also discovered the Skin in Hitchers GitHub and it is really a awesome Skin! Love the new Views. He also included PVR/TV-Support!
Thank you very much Hitcher and QuizKid!
The Colour Customisation isnt working yet (for me), but i think this is intended
We haven't included PVR support it's just there because I'm building from Conq.
Nevermind. Still awesome!
This skin is getting better and better. I love the new dialog menus in v 0.0.33.
Thanks for keeping up the awesome work.
Is this still being worked on, or has development stopped?
Work seems to be continuing on this skin. There have been many updates to the Github files....it's just slow going.
The wait will be worth it imo.
Thanks for keeping interest -- we're still going, but it's been slow lately what with work and other projects.
Understandable....good things come to those who wait!
I'm a fan!
Looks great; can't wait to test it.
That's very unique skin, great work guys!
This looks awesome!
Is it going to be Krypton only though? (since gui version is set to 5.11)
(2016-02-14, 11:11)Hitcher Wrote: [ -> ]As someone found out it's on my GitHub repo - https://github.com/HitcherUK/skin.copacetic - but only use if you know what you're doing and please don't ask for support as it's still in development.
I downloaded zip from github and manually extract it into addons directory (installing it from zip file gives me dependency not met error). I can choos the Copacetic skin in Kodi skin settings but nothing happens. It doesn't load it. I use Kodi 16.0 stable version. Is there anything I've missed?
(2016-02-26, 15:01)qzem Wrote: [ -> ] (2016-02-14, 11:11)Hitcher Wrote: [ -> ]As someone found out it's on my GitHub repo - https://github.com/HitcherUK/skin.copacetic - but only use if you know what you're doing and please don't ask for support as it's still in development.
ever thought about what the "dependencies not met" error could mean that you seem to ignore?
(2016-02-26, 19:00)da-anda Wrote: [ -> ] (2016-02-26, 15:01)qzem Wrote: [ -> ] (2016-02-14, 11:11)Hitcher Wrote: [ -> ]As someone found out it's on my GitHub repo - https://github.com/HitcherUK/skin.copacetic - but only use if you know what you're doing and please don't ask for support as it's still in development.
Well I often get dependencies not met when trying some unofficial addons and they often work anyway when you manually extract them. So I thought here could be the same, since there are others who managed to get this skin working...
Sent from mTalk
