Full Version: TVLogo Downloader
Pages: 1 2 3 4
thank you for your job..Blush
can you explain me how to set like the video (2:13 min); in my KODI (15.1 Isengard) "download logo" option is missing.No
I 'd like to use this option to change missing logos and/or wrong logos
I have to set the addon or something is missing?
Any help would be appreciate
Read the first post, the context menu item is another addon (context.tvlogodownloader) and only works for Isengard++. Also there is a bug with encoding (special characters) for arm devices which I haven't yet found time to solve. From the context menu it seems to work fine though.
I read the first post, but i see: "This feature is available only for Kodi versions higher than v15"...i suppose that my version is not Isengard++ and that we are talking about beta release.... or not?
By Isengard++ I mean any version equal or higher than Isengard since context menu addons were only introduced in Isengard. You'll have access to context menu items (as addons) for isengard and Jarvis. Which version are u running?
15.1 (current release)
So after installing the context.tvlogo downloader (1st post) it should be available
(2015-08-28, 15:52)enen92 Wrote: [ -> ]So after installing the context.tvlogo downloader (1st post) it should be available
I had already done before writing the forum.. it does not works..i'll try to install again..
ok..now it's works
Has this made it to the official repo yet?
Unfortunately no...it is not guaranteed to work in every single platform. It would require a litlle change in Kodi itself however it looks no one is interested in adding that functionality:
http://forum.kodi.tv/showthread.php?tid=244198
Hi everyone.
I am still a newbie with Kodi and still need to learn a lot.
I did download both the zip files for the addon (context and script) but whenever I try to install any I get an error message saying that the installation failed because some dependencies are not met. are there any pre requisites for the installation? I am running Kodi Isengard 15.2 on an Android TV box.
Thanks a lot for your help.
You can always check the debug log for details of the error. Usually a missing dependency yes.
Thank you for your quick reply.
I tried checking the log files, I found the debugging message but I have to admit I don't really understand what's the issue and obviously not how to solve it.
Here's a little dump of the log file, I would very much appreciate if somebody could guide me on the next steps to follow to get it installed.
19:09:46 T:18446744072347140864 DEBUG: Keyboard: scancode: 0x14, sym: 0x0112, unicode: 0x0000, modifier: 0x0
19:09:46 T:18446744072347140864 DEBUG: bool CInputManager::OnKey(const CKey&): down (0xf081) pressed, action is Down
19:09:46 T:18446744071793916288 DEBUG: static std:Confusedtring CTextureCacheJob::GetImageHash(const string&) - unable to stat url /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.axel.downloader/icon.png
19:09:47 T:18446744072347140864 DEBUG: Keyboard: scancode: 0x14, sym: 0x0112, unicode: 0x0000, modifier: 0x0
19:09:47 T:18446744072347140864 DEBUG: bool CInputManager::OnKey(const CKey&): down (0xf081) pressed, action is Down
19:09:47 T:18446744071880107776 NOTICE: Thread JobWorker start, auto delete: true
19:09:48 T:18446744072347140864 DEBUG: Keyboard: scancode: 0x14, sym: 0x0112, unicode: 0x0000, modifier: 0x0
19:09:48 T:18446744072347140864 DEBUG: bool CInputManager::OnKey(const CKey&): down (0xf081) pressed, action is Down
19:09:48 T:18446744072347140864 DEBUG: Keyboard: scancode: 0x13, sym: 0x0111, unicode: 0x0000, modifier: 0x0
19:09:48 T:18446744072347140864 DEBUG: bool CInputManager::OnKey(const CKey&): up (0xf080) pressed, action is Up
19:09:48 T:18446744072347140864 DEBUG: Keyboard: scancode: 0x42, sym: 0x000d, unicode: 0x000a, modifier: 0x0
19:09:48 T:18446744072347140864 DEBUG: bool CInputManager::OnKey(const CKey&): return (0xf00d) pressed, action is Select
19:09:48 T:18446744072096324992 NOTICE: Thread LanguageInvoker start, auto delete: false
19:09:48 T:18446744072096324992 INFO: initializing python engine.
19:09:48 T:18446744072096324992 DEBUG: CPythonInvoker(49, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.xbmc.debug.log/addon.py): start processing
19:09:48 T:18446744072096324992 NOTICE: -->Python Interpreter Initialized<--
19:09:48 T:18446744072096324992 DEBUG: CPythonInvoker(49, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.xbmc.debug.log/addon.py): the source file to load is "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.xbmc.debug.log/addon.py"
19:09:48 T:18446744072096324992 DEBUG: CPythonInvoker(49, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.xbmc.debug.log/addon.py): setting the Python path to /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.xbmc.debug.log:/:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.kodi-2/base.apk/assets/python2.6/lib/python2.6/lib-dynload
19:09:48 T:18446744072096324992 DEBUG: CPythonInvoker(49, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.xbmc.debug.log/addon.py): entering source directory /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.xbmc.debug.log
19:09:48 T:18446744072096324992 DEBUG: CPythonInvoker(49, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.xbmc.debug.log/addon.py): instantiating addon using automatically obtained id of "script.xbmc.debug.log" dependent on version 2.12.0 of the xbmc.python api
19:09:49 T:18446744072347140864 DEBUG: ------ Window Init (DialogAddonSettings.xml) ------
19:09:49 T:18446744072347140864 DEBUG: LocalizeStrings: no strings.po file exist at /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.xbmc.debug.log/resources/language/English, fallback to strings.xml
Post a full http://kodi.wiki/view/Log_file/Easy to http://xbmclogs.com and it will show the error.
well that's more or less what I did. I thought pasting just the relevant part of the log would've been nicer than having all of it.
Anyways I generated a new (hopefully cleaner) log: http://xbmclogs.com/pif2tgarh
I have to admit I still didn't see what the real issue is. Maybe the part where it says 'no strings.po file exist'.
Pages: 1 2 3 4
