2015-07-25, 16:51
Hello all,
I don’t know where to slot this request in but I hope I’m in the right place.
Most of you must have heard about this box. It works well for me and many others. Though the community is not very large, if I’m not mistaken, but it seems to be growing.
I would like to request for a PVR-Client plug-in for Kodi that streams Live-TV from the Amiko A3 box. Currently an app is being used on android systems and web browser on PC. The PC part is great but the android part is troublesome. Generally, it would be more comfortable to stream using PVR-Client in Kodi.
The web browser uses JASON to interact with A3 so it is easy to parse channels and EPG, send few commands and receive selected stream from it. If you require some output I will be glad to provide some. Just streaming and Showing EPG will do for now, and maybe later, send recording commands, time shifting and scheduling as it grows. One could eventually modify an existing PVR add-on to achieve this.
I'm asking because I lack the knowledge to create plugis.
I would appreciate a favourable response.
