2015-07-28, 04:24
Ever since Windows Media Center switched from Zap2it to Rovi for the Guide provider, I've noticed that ServerWMC will stream the SD version of the channel instead of the HD on some channels.
My current setup is a HDHomeRun Prime and my HTPC which is running Windows 7 Pro (64-bit) and WMC, ServerWMC (1.0.0.58 Build 1199) and Kodi (15.0).
For example, if I go into the guide in Kodi, and select BBC America, it shows the Standard Definition version of the channel. However, if I select the same channel in Windows Media Center, it properly shows the HD stream. Likewise, if I go into Kodi, and tell it to record the channel, it records and plays back correctly in HD.
I've also tested this on my iPad Air 2 which is running Kodi 15.0 and also a second PC I have which was running Kodi 14.2. Both show the SD version of the channel instead of the HD. Most channels do show the HD stream as they should, but a certain number of them will show the SD instead.
Any clues as to what would cause this? I've tried resetting the PVR database on all three computers (the one running 14.2 was installed after I started noticing this issue), and I've forced ServerWMC to reload the channels from WMC but no luck.
Here are the log files from both Kodi and ServerWMC.
Kodi:
http://pastebin.com/zzdqWwrD
ServerWMC:
http://pastebin.com/Ri6STnFS
Kodi:
ServerWMC:
