Hi im new guest and hope to get an answer...sorry if this is not the right site....
I have a matricom gbox Q ......i did update fr 14.2 to 15.0 isengrad ....
The picture is not in the center of the screen all movies not in the center
It is always on the right side of the screen..i need help pls how to correct
This issue.....thank u ......
(2015-07-28, 09:12)Jbernardino Wrote: [ -> ]Hi im new guest and hope to get an answer...sorry if this is not the right site....
Ok in your android firmware display settings set it to 720p then go back in to kodi. Try it
now.
I am having the same issue. Im using the latest stable firmware via OTA. On kodi 15, and now 15.1 when watching a video, the picture will be offset and to the right, it puts the video to the lower right hand side of the screen. I have tried going to display on the Gbox and setting hdmi to 720P, issue still occurs. Any Fixes?
In your Kodi System Settings, make sure you are in Expert mode (bottom left corner). Go to Video, Acceleration and uncheck the amcodec.
Exit Kodi and start it up again. It should work now.
Go to G Box Q setting and and disable HDMI auto detect.
