Full Version: How could I display the entire GUI of tMM?
After the update to 2.6.9 I cannot get the bottom of tMM displayed anymore: http://i.imgur.com/BupOg7I.png
Or, if not possible, could I just download the previous version and over install it?
we did not change anything here for 2.6.9
you may try to resize the window (not only maximize/restore).
And if that does not work, close tmm, delete the file tmm_ui.prop and all window sizes are reset to default
Thank you, mlaggner.
Oops, I thought...but since I use tMM I have some slight issues with the window (size).
Yes, had tried without success.
Done. It didn't work obviously. It looks like:
http://i.imgur.com/yxRecdZ.jpg
http://i.imgur.com/Pamy50q.png
http://i.imgur.com/hSio1Z9.gif
There do not appear to be scrollbars. So I could scroll down / up (or vertically) the content of the window.
Or, if not possible, could I just download the previous version and over install it? The previous version did not behave like the new one.
Thanks again.
okay, now I see it.
you can temp. fix it: just switch to the TV show section and back and it should look like it should.
I'll investigate meanwhile
Ah, unbelievable, that works, great, switching back and force...how could one know...
Alright, so have a successful investigation.
Many thanks
hotfix is out - should now work as desired
Great, that was very fast, many thanks, mlaggner.
Hmmm, may be there still is a slight glitch or so, after tMM's start it looks like that and when I click update data sources it almost looks the same: http://i.imgur.com/zZOlyal.jpg
When I click the tab TV-Shows and then go back it looks like: http://i.imgur.com/Xs3Q2cI.jpg
