Full Version: kodi 15 upgrade
I have an MXq box and have just upgraded from 14.2 to 15. All video playback is now in a small window approx 1/4 size in top left corner. I uninstalled and installed 14.2 again and all is ok apart that i lost everything.
Is this a known fault?
I did look through all the settings but could see nothing that would let be change the playback window size. the zoom function just zoomed to full screen but only showed part of the full picture
Search the forum, you'll find numerous threads just in the past months dealing with this and advising options. Set your box to 1080P@60hz in the android settings, not auto.(some have said) If need be, try disabling the Amcodec hardware decoding in the acceleration menu(SYSTEM:Video:Acceleration) of KODI and the MediaCodec should handle accelerated decoding for you if I remember correctly. Do the forum search and read up. Good luck.
EDIT: Ned beat me to it while I was typing...
