Full Version: Amber Skin for Kodi 15 Isengard
Pages: 1 2 3 4 5 6 7 8 9
So,
Now that we have Isengard release, I will use this thread as a placeholder for all issues that need to be fixed for Isengard.
to be clear, NO feature requests, just fixes to make Amber work properly with Isengard.
Just explain the issue in a post (with screenshots is better) and I will look at them one by one and hopefully fix them Smile
Also, i'm going to work through this list to make sure all the changes are done (lots of work)
http://forum.kodi.tv/showthread.php?tid=211896
P.S.
If you REALLY want to help, i'm open to pull requests and/or problem reports here:
https://github.com/jester-xbmc/skin.amber
EDIT:
Video done by Martijn after 15.1 release
https://www.youtube.com/watch?v=a4uzJHtSPic
Hi Jester
I have updated the skin with the Isengard skinning changes plus fixed a few things (mainly PVR windows\SublimeKodi flagged errors) and it is working fine for me. Unfortunately I am away on business and can't upload until I get back home on Friday.
I'll submit a pull request once I get home for you to review.
Kevin
Hi Jester
I have just sent you a pull request for my changes for Isengard support and fixes, I hope they look ok, let me know if you have any problems.
Kevin
Hello,
I have Windows 8.1 64-bit and Kodi 15 Isengard. I like Amber skin a lot and in Library mode I use Big List view. But in Big List view the background is just black. How can I enable artwork in backgroud for Bil List or at least to put some picture instead of pure black background?
Sorry if this was answered previously, but I searched the forum and couldn't find any answer.
(2015-07-31, 12:28)joethepartylion Wrote: [ -> ]Hi Jester
Kevin
Cheers Kevin,
I'm traveling myself for work, I will take a peek later tonight and push some updates myself and merge what looks ok.
Hi there,
With the new addition of chapters, the bookmark menu when playing a video isn't display any picture nor visual selection of chapter.
Thanks for keeping Amber alive!
just an issue with the new Adaptive seeking (aka Skip Steps) feature: when I press the seek back/forward button I see no immediate feedback about the skip period, we should see 10 seconds / 30 seconds / 1 minute etc.
I can only see that at the end when the player is skipping, test it with the default Confluence skin.
(2015-08-01, 23:07)fab42 Wrote: [ -> ]Hi,
Thanks, this one is fixed in my pull request to Jester.
Kevin
I've merged your pull, thanks !
some other changes have been done, i'm currently testing, will push an isengard release soon
Ok thanks
I just checked out a copy from Github and started my own testing, I will report here any issue I should notice.
A visual nuisance I just discovered (actually using version 2.1.0 from Github):
Going to a Movie or Episode "Info" screen and then into the "Actors" section, when I highlight an actor's name his/her picture is properly showed but the name disappears because it's covered by a black/white image that I guess should be a transparent background but covers instead the actor's name.
Could someone please take a look at https://github.com/pecinko/skin.amber/issues/88
(2015-08-03, 07:42)Smultie Wrote: [ -> ]Could someone please take a look at https://github.com/pecinko/skin.amber/issues/88
Hi
The problem with this one is that the icons can be different aspect ratios and at the moment the images are all stretched to fit the container. It can be changed so that the aspect ratio is not changed during the stretch but then the border will no longer fit the image perfectly as it isn't possible to dynamically detect what type of image is displayed and modify the border accordingly.
I guess this is why the Confluence skin uses a list and only shows one icon at a time so this issue isn't visible.
It comes down to what would people prefer:
1. Stretched icons, consistent border
2. Correctly proportioned icons, inconsistent border.
3. A different way of displaying it entirely, (if so, what?)
Kevin
(2015-08-03, 11:41)joethepartylion Wrote: [ -> ]
Hi
Kevin
Being consistent with the borders would solve my specific problem I think?!
Hi
Kevin
I guess that removing the border is not a good thing because it would break the skin's visual consistency, so I think that option 2 is better than option 1 (actually in use).
Did someone check the actor's name issue I reported yesterday? I tried myself but I'm not skilled in Kodi skins.
