Full Version: HDHomeRun + Synology NAS + IPTV Simple Client
I've spent a lot of time over the past few days working out all the bugs and working through most of the gotchas to create this PHP library for use on a Synology NAS. Technically, it could be adapted to run on any server with PHP installed.
It's my first contribution to the community and I hope it helps others out! I also look forward to hearing people's comments and suggestions for improvements in the future.
HDHR Assistant
https://github.com/goyney/hdhr-assistant
The HDHR Assistant is a PHP library designed to run on your Synology NAS to provide channel and an Electronic Programming Guide (EPG) for use in the IPTV Simple Client PVR add-on for Kodi.
Advantages
  • Use Kodi's built-in Live TV interface, include Radio Stations
  • No need to launch any third-party applications
  • More control over how your channels display
  • Extensive EPG information
Disadvantages
  • You cannot record or pause live TV
  • Not as easy as just downloading and using the HDHomeRun VIEW application or Kodi add-on
Requirements
  • Synology NAS with PHP web server enabled
  • HDHomeRun device on your local network
  • Kodi 15+
  • IPTV Simple Client PVR add-on
  • Perl (To run the Zap2XML script, provided in this repository)
