Full Version: [Bug] Playing Zip Files in a Queue doesn't work
If you have CDG+MP3 files in a zip file they play fine either if you select at the top zip level or if you select the zip and then see the MP3.
If you try to add either the zip or the MP3 in the zip to a queue, when the song is next to be played and the current song ends Kodi crashes. Files not in a zip (ie CDG+MP3) seem to queue fine.
I'm on Kodi 15 from the play store and Android 4.4.2
