first of all, thank you for this killer Kodi skin. My problem are somewhat ugly looking backgrounds compared to the fan made ones that are automatically downloaded. Even though my custom ones are quite decent when viewed in any other program and are 1920x1080 pixels in size.
Thank you in advance!
Take a look at the wiki instructions and be sure to put it in your userdata folder. Kodi 16 will include more image scaling options that will likely improve image quality as well.
Got it to work, thank you!
Hello may i ask how u got it Fixed?
I have a simmilar Problem with custom Background but only when i use Amber Skin.
On Confluence everything works Fine Custom backgrounds stay sharp and dont get Pixelated.
But when i use Amber skin the same Picture looks very bad when i select custom Background via Settings/Backgrounds on Kodi MenĂ¼.
The Strange things is when i replace the Standart Backgrounds located in AppData\Roaming\Kodi\addons\skin.amber with my custom Backgroud and rename it the Picture dont get Pixelated
but i dont want to manually move and rename the Pictures everytime when there is a Setting in the Kodi MenĂ¼ (wich doesnt work)
Any clues ? I tryed that method with Advancedsettings.xml but i has no effect
Also my Android Version of Kodi with Amber doesnt have this Problem...
only my Windows7 Pc wich i want to setup now
