2015-07-31, 10:21
2015-07-31, 10:24
this week
2015-07-31, 10:48
2015-07-31, 11:22
By the way, i am not able to rsync-read from z.os6.org from our server, could you take a look at that ? It effectively disables that mirror.
2015-08-01, 00:09
I like Mirrorbits way better than mirrorbrain. Mirrorbits is so simple to setup.
I was wondering why both of the mirrors were balanced and noticed someone upgraded to mirrorbits. It load balances rather than relying on geoip. I just setup a second nic on z to cope with the bursts and now i doubt it will max gbit PP
Kib,
I saw that yesterday.
i think someone fat fingered the url and added it as "zee.os6.org".
I made a cname from zee.os6.org > z.os6.org and its working now :p
Do you have a cpu graph while it was mirrorbrain? I'm curious how the load has changed.
Are you going to go down the mirrorbrain cluster route once mirrorbits releases it? seems interesting : ]
keep up the good work
Kib,
2015-08-01, 00:14
stats stats stats : ]
http://mirrors.xbmc.org/releases/win32/k...irrorstats
leaseweb is stealing all my traffic!
2015-08-01, 00:23
it was a quick import from an outdated spreadsheet which wasn't kept up to date with mirrorbrain. Still lots of tweaking needed.
Mirrorbrain was good while it lasted but we simple outgrew the vast amount of data/connections
2015-08-01, 09:20
2015-08-01, 14:51
Huh, interesting. It was not fat fingered at all.
I manually set it up as zee.os6.org in description only, the url is set up as z.os6.org.
The reason for this was I couldn't put it back when it was set as z.os6.org because it complained it was already in the database that way.
(which is a seperate issue I need to discuss with etix, the creator if mirrorbits).
It should not connect to zee.os6.org at all, this would mean we discovered a bug where it connects to the descriptive name instead of the rsync url set up.
Wrote a ticket about the editing / removing bit of mirrorbits here: https://github.com/etix/mirrorbits/issues/19
I've managed to get the flakey key out of the database and readded the mirror as z.os6.org
Mirror: zee.os6.org
HttpURL: http://z.os6.org/xbmc/
RsyncURL: rsync://z.os6.org/xbmc/
FtpURL: ""
SponsorName: OS6
SponsorURL: ""
SponsorLogoURL: ""
AdminName: <redacted>
AdminEmail: <redacted>
CustomData: ""
ContinentOnly: false
CountryOnly: false
ASOnly: false
Score: 20
Latitude: 34.0438
Longitude: -118.2512
ContinentCode: NA
CountryCodes: US
ASNum: 8100
Enabled: true
2015-08-01, 16:14
Etix already fixed the issue:
https://github.com/etix/mirrorbits/commi...80c1c31251
2015-08-01, 20:54
wow Etix is a beast!
2015-08-02, 01:35
I'm waiting for someone to make a opensource mirrorbits mirror network. So many projects that would benefit from it.
