Full Version: constant buffering after upgrading unraid server to 6.0.1
I'm looking for some help trying to figure out a streaming issue with Kodi after upgrading my unRaid server to 6.0.1. After the upgrade, I end up with constant buffering issues anytime I attempt to play anything on Kodi. I've even tried streaming to Plex as well and I see a similar problem. The audio and video queues go to 0, then it buffers for a while and starts playing again, then a few seconds later the queues go back to 0 and starts buffering again.
I've tried everything I can on the kodi side. I've tried doing CIFS, NFS, and SMB mounts and all behave the same way. I've added buffering with 100MB in the kodi advancedsettings.xml file, and that does nothing to address the issue. When just copying files from the unRaid server to my htpc an pull files down around 40MB a second. I've tried different network cables and nothing seems to help. I've tried both Kodi 14.2 and 15.0.
Just to test, I loaded the backup of unRaid 5.0.5 back onto the server, and now I am able to stream just fine. It seems to be an issue only with this client. I've tested unRaid 6.0.1 streaming to other machines and they work fine. But for some reason, this particular combination is causing problems.
Here is a brief snippet of what I see from the kodi log file (full file attached).
20:07:10 T:4884 WARNING: DXVA - decoder problem of status 2 with 255
20:07:10 T:4600   DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
20:07:10 T:4600   DEBUG: ------ Window Init (VideoFullScreen.xml) ------
20:07:10 T:4600    INFO: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY
20:07:10 T:4600   DEBUG: ------ Window Deinit (VideoOverlay.xml) ------
20:07:10 T:4600   ERROR: DXVA - failed executing m_process->VideoProcessBlt(target, &blt, &samp[0], count, NULL) at line 714 with error 80004005
20:07:10 T:4600   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
20:07:11 T:3124 WARNING: Previous line repeats 2 times.
20:07:11 T:3124   DEBUG: CMMNotificationClient::OnPropertyValueChanged: Changed device property of {0.0.0.00000000}.{719a980a-ae17-465e-bfa0-5377d6402f48} is {9855c4cd-df8c-449c-a181-8191b68bd06c}#0
20:07:12 T:1824   DEBUG: CDVDClock::Discontinuity - CDVDPlayerAudio::HandleSyncError2 - was:1859326.465796, should be:1839268.525826, error:-20057.939970
20:07:13 T:4600   DEBUG: Keyboard: scancode: 0x18, sym: 0x006f, unicode: 0x006f, modifier: 0x0
20:07:13 T:4600   DEBUG: CApplication::OnKey: o (0xf04f) pressed, action is CodecInfo
20:07:14 T:1824   DEBUG: CDVDClock::Discontinuity - CDVDPlayerAudio::HandleSyncError2 - was:3849331.013124, should be:3833309.389146, error:-16021.623977
20:07:15 T:4884   DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000
20:07:15 T:1824 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:07:16 T:4884 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:07:16 T:1824 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:07:16 T:2652   DEBUG: CDVDPlayer::SetCaching - caching state 1
Kodi Log File
Media Info
Hardware Information:
unRaid Server: Intel Celeron G530 2.4Ghz Dual-Core, 4GB ram, unRAID 6.0.1
HTPC: Intel i3 530 2.93Ghz Dual-Core, 4GB ram, AMD Radeon 5570, Win 7 SP1 x64, Kodi 14.2 / 15.0
Update: I have my issues resolved. I have been in the process of upgrading components. One of which is my server chassis. I just got the last of the new hardware today and got everything setup and in the new chassis. With the new hardware for the server, everything is now running perfectly smoothly.
So now I'm wondering if it had something to do with my old hardware. I was running a Celeron G530 with 4GB ram on an Asus P8H67-M PRO mobo. Perhaps the newer linux kernel, or something with the network drivers didn't like the older chipset. I did run wireshark with the old hardware and I was noticing a number of retransmits from the server. Nearest I could tell, the client seemed slow to send ACKs for some periods, then the server would send a retransmit. So no real explanation, but new server hardware fixed it for me.
That rather sounds like broken network cable - did you also change that by accident? A G530 is by far fast enough for such a scenario.
No I had tried multiple network cables. All cat6.
