Full Version: Kodibuntu login loop
Hi all,
I downloaded the latest version Kodibuntu from the site and installed it (Kodibuntu 14.0). So far so good...but then after installing and configuring it crashes at exact the same point for 5 times in a row!
These are the steps which I took:
- Installation Kodibuntu 14.0
- update/upgrade
- Installed my Sundtek tuner
- Tvheadend
Then I have to do a restart to see the tvheadend add-on in Kodi. This add-on is active and only needs an username and passwd. The last step before completing installation is to turn on Live TV in Kodi. This disables the tvheadend pvr-client. The moment I enable the tvheadend pvr-client my system crashes and I end up in a loop. I can't login anymore and my system keeps rebooting.
Killing tvheadend and restarting lightdm does not fix this problem. Does anyone recognize this issue and have a solution for this? It kept me awake the entire night!
Thanks in advance!
not sure what's going on on your side however we're working on our own backend to make things easier with our tuners.
I guess it will take 1-2 weeks until we'll release the first version of it.
Be sure you are using a USB 2.0 port, some USB 3.0 controllers are not well supported by linux and are able to crash Linux.
http://support.sundtek.com/index.php/topic,1940.0.html
Found the solution
sudo apt-get dist-upgrade did do the trick!
Aargh..same problem again!! But this time if i do dist-upgrade, it will only start in Kodi Desktop and here is no Kodi in the pulldown menu. Only Lubuntu and Lubuntu-netbook
If I do sudo service lightdm restart, my screen starts to flash and returns to Kodi Desktop.
How can I force to kill Kodi Deskop and return to Kodi?
please provide the output of:
apt-cache policy kodi kodi-bin
Here it is...i am back at 14.10 and now there is Kodi in the pulldown menu. But as soon as I select Kodi and log in, I get the same result as mentioned above.
If I (dist-)upgrade and go to v16.1 I loose Kodi in the pulldown and the flickering goes on..
Bizarre thing is, it crashes at exactly the same moment every time.
Steps:
- clean install 14.10
- install tv tuner (sundtek)
- configure tvheadend
- install tvheadend
- and literally as soon as I start tvheadend in Kodi my system crashes and I end up in Kodi desktop.
Last login: Thu Oct 27 23:15:20 2016 from 192.168.1.3
ali@Ali-Kodi:~$ apt-cache policy kodi kodi-binkodi:
Installed: 2:14.0~git20141223.1015-final-0trusty
Candidate: 2:16.1~git20160424.1410-final-0trusty
Version table:
2:16.1~git20160424.1410-final-0trusty 0
500 http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ trusty/main amd64 Packages
*** 2:14.0~git20141223.1015-final-0trusty 0
100 /var/lib/dpkg/status
kodi-bin:
Version table:
ali@Ali-Kodi:~$
Fixed!
My steps:
- clean install
- update
- upgrade
- dist-upgrade
- install tv tuner
- install tvheadend
In this order everything is installed and no errors
