Full Version: UPNP not working KODI 15?
Not sure if it's related to this thread:
http://openelec.tv/forum/69-network/7557...ing#143287
Running 6.0 Beta 3 on and Intel NUC and Chromebox. UPNP is not detecting any devices (i.e HDHomerun Prime) when trying to add it as a new source. I can see the HDHomerun and Kodi as UPNP devices in Windows 10.
Interestingly enough, if I disable UPNP in Kodi, then turn it back on the HDHomerun is detectable. However, after I add it as a source, none of the links (channels) work. Rebooting, the UPNP source is no longer working. Logs attached and video link below. Thanks!
http://pastebin.com/aq6g28gE
Bump, anyone else running into this problem with KODI 15?
Yeah, known issue. It's being looked into.
I'm having a similar issue with 15.0 and 15.1. I have two HDHomerun Prime devices.
With 14.x I used to be able go to Videos and Files, where I could Add a new "Files" entry by using:
Video->Files->Add videos and Browse UPNP to select my HDHomeRun Device->Channels and give it a Name.
I do this for both HDHomerun devices.
Then to Watch, I would just to to Videos->Files- and select the Name and Channel to watch a stream.
Using this method I could select a specific HDHomerun device and channel.
This no longer works in 15.x.
The Only streaming working is to use the HDHomerun Add-on.
I have a debug log if needed.
