Full Version: Problms with VNSI/Kodi 15 and HD Chanals
hello,
I have a problem with kodi 15. Every time when I try to switch to a HD channel I got an error "channel: scambled (2)"
VDR is installed on a separat tv-server. when I use my laptop with Kodi 14 it works perfect... And I can watch the
same channel on Kodi 15 during I have the same channel is enabled... So I think the problem is not the VDR plugin...
so I don't know what is wrong...
what vdr plugins do you have loaded on the server?
I have installed the following plugins...
dvbapi
streamdev-server
epgsearch
live
epg2vdr
can I use the VDR-VNSI-Client 1.09.22 with Kodi 15
with this version I have no problem...
try setting priority to 0, vnsi addon configuration.
okay, that helps...
thanks...
