2015-08-04, 09:52
Hi guys new to the forum so sorry if this post is not in the correct location.
please can somebody help me i have kodi loaded onto a Amazon fire stick and was wondering if there is any apps i can add to the actual amazon side of it not in kodi that will allow me to restore the setup to a saved point?
for example on my android box there is a addon called xbmc helper that can be used without opening kodi so if kodi breaks i press the button and it restores it but the main point is it restores it already setup not stock.
Is there anything like that i can use on the fire stick.
I know you can save a restore point using the program on your computer that was used to setup the stick but i really need a app on the actual stick.
Basicly the stick i setup i gave to my dad and he doesnt have the program or any idea how to work it so a nice little app would be great
Thanks for reading
Thanks for reading
