2015-08-04, 12:09
HI all,
Recently bought a projector and am trying to plug it into my existing Kodi setup.
My existing setup passes audio and video from an Acer Revo running Kodi via HDMI, to a Yamaha RX-V765 amplifier, then onwards to a Panasonic TX-P50G20B. This is able to handle 24hz correctly (for movies in the appropriate frame rate).
Replacing the Panasonic TV directly with my new Optoma HD141X causes no problem either. Kodi recognises the capabilities of the projector, and offers 24hz mode.
However adding an HDMI splitter (http://www.ebay.co.uk/itm/271931721149) into the mix (to enable both displays to connected) removes the 24hz option from the video settings screen in Kodi.
I presume this is due to an EDID issue with the splitter (whereby it is not passing through the EDID information from either display correctly)?
What's my best solution? To buy a new splitter that does correctly pass EDID, or can I set Kodi such that it has fixed EDID rather than it reading incorrect EDID information from the splitter?
Thanks in advance.
Thanks in advance.
