2015-08-06, 10:37
RKM MK12 + AMLOGIC S812 (h265 @ 4k capable) + 2 GB RAM + (originally) rooted Android 4.4.2, *issues* with Kodi 15.0
# "Allow hardware acceleration - amcodec" - skipping FFW or RW (pressing up/down or back/front arrows from remote) h264 files, it freezes the image but the sound continues. DISABLE to fix the issue (though I do not know if videos still run through hardware) (tis issue was NOT present on Kodi 14.2);
tested today with some h264 files and I got mixed results: most files play nice (with amcodec OFF) and no sync issues when I skip forward; some other files are laggy and lose frames, but if I turn amcodec ON, then they play silk smooth. On Kodi 14.2 they work all perfectly with amcodec ON.
# h264 & h265 files have now and then some freezing/syncing issues (no issues on Kodi 14.2)
# like on Kodi 14.x, sometimes it does not find subtitles on "opensubtitles" when on the website/through other apps (MPC, etc) it recognizes and downloads pretty well. (also on Kodi 14.2)
# still no function to clean the "garbage" left on the add-ons folder: 1) it could be made an option "leave only the two most recent add-on packages"; 2) the NOT installed skins could stay compressed, else there are TONS of files & images taking up the precious space; 3) thumbnails cleanup option where all images associated with removed ADD-ONs/movies would be removed; 4) option to choose what thumbnails should be downloaded (ex: "only cover" "cover + actors" "cover + fan art" etc etc), so people could limit the amount used.
Personally I find Kodi fantastic, *but* with no "cleanup" function/"compress unused add-ons", it is too inefficient and uses too much space to be used freely on Android devices...
