2015-08-07, 19:58
2015-08-07, 21:55
the reason I want to put m3u file into URL, when I update m3u and upload back to site.. I do not need to push new update file back to amazon fire tv stick. If I have in local I have to push update file to the device.
thanks
thanks
2015-08-08, 09:39
You could stick it on dropbox and then get an HTTP url for the m3u file, as long as it is in your public folder.
2015-08-08, 12:26
I do the same with my nas using its web publishing service.
new dropbox subscription have not free public folders IIRC.
Peppe
Peppe
2015-08-08, 15:12
That is smart idea using drop box. I will give a try if I can use for free subscription
but what if i want to use web site like I see some people using like VDUB215 please guide me to any resource I will check it out
2015-08-10, 04:17
I sent the file to dropbox and create shortlink of the file. it works
thanks
thanks
