I have some movies that are extended cut and directors cut and so on.....
What is the best way to add the correct pictures to TMM?
Is it possible to rename in TMM, if so. Is this the best way to do it, or is it better to do it in Kodi?
Thx
Having the same movie in different versions is always a problem.
The trick here is, to find the difference between, and use the renamer to create a duplicate movie here.
Dunno how kodi handles this...
But would be nice when tmm could read this from filename and add behind title (shown name) - so could have a movie in different cuts/folders
like:
Lord of the Rings - Directors Cut
Lord of the Rings - Extented Cut
and when nothing in file name than just:
Lord of the Rings
edit: and dont wanna start new thread for this - but could it be possible to write the "video source" in the .nfo ?
i know its allready in tmm and i can write the source in filename, but other programs can not find it.
Been thinking about it as well. So far,the best you can come up to is scraping the film first, edit the tile field to Lord of the Rings - Directors Cut and then rename file and folder using the title token.
