Hi i was wondering if anyone knows how to fix an android box that is constantly crashing, i have uninstalled kodi, 5.0 .then re installed 4.2 version but the problem continues every time. It works fine until i turn kodi off then everything is wiped, i would appreciate any help at all with this, thanks.
Maybe start with adding some relevant info ?
For starters, what are you running on the box, do you have a crashlog, what hardware is it etc
NOT SURE I KNOW WHAT YOU MEAN AS I AM NEW TO THIS AND STILL TRYING TO FIND MY WAY ABOUT, I HAD 5.0 VERSION OF KODI, SO I DELETED AND RE INSTALLED 4.2 KODI, THEN I DID A RE STORE FROM AN SD CARD AFTER RE INSTALLING TOTAL INSTALLER. ALL I AM TRYING TO FIND OUT IS IF THIS CRASHING PROBLEM CAN BE FIXED AS IT HAS SEEMED TO BE HAPPENING TO OTHER PEOPLE ALSO.
