Hi I noticed that Kodi exports your tags into the info file but it does not import them and you have to re-add all your tags so this is my humble request. PS, I'm using Isengard.
Best media center on the planet!!! Thanks for all the hard work and dedication!!!!
I meant video tags, but I just re-exported all my info files and then tested importing a movie with a tag and it did in fact import the tag, I must be loosing my mind because for the life of me I could not get the tags imported
Anyway, it seems to be working now so thanks
Apologies for the pointless post.
By default the NFO information is imported (if a scraper is set on the source), except for the watched states and resume points, which can be adjusted by setting
<importwatchedstate>true</importwatchedstate> <!-- import previously exported playdate and playcount from .nfo files. Defaults to false -->
<importresumepoint>true</importresumepoint> <!-- import previously exported resume point from .nfo files. Defaults to false -->
within
advancedsettings.xml (wiki)
