Full Version: Can't enable option button
I use Xperience1080 3.5 with Kodi on a raspberry pi 2 (Openelec).
When I goes in the setting to enable the options "show options button in views" (something like that, sorry I don"t remember the exact name) I can't because the options is disabled. Impossible to change it's value.
Si I cannot change the options in the movies or series to view watched media.
What should I do to be able to enable this option ?
regards
The button may not work (although you're the only person to report this), but the menu is still there.
3.5 is no longer support, you should upgrade to Isengard and use v4.x of the skin.
